Help in changing out clutch
Old Jul 21, 2004 | 10:15 PM
DrewDown's Avatar
Default Help in changing out clutch
Im in the process of swapping out my clutch and Ive never done something of this magnitude. Anyway today I got stuck because I could not get the tranny separated from the motor. I have a 93 integra LS. My manual says that I only have to remove the upper starter bolt. But I searched and found that on some cars the lower bolt must be removed. Is this my problem?. I recently changed my starter and I remember the lower bolt was a lot longer than the upper.
Im stressing out cuzz this is my only means of transportation and any help would be appreciated.
Old Jul 21, 2004 | 11:43 PM
Cjsls's Avatar
Default Re: Help in changing out clutch (DrewDown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewDown &raquo;</TD></TR><TR><TD CLASS="quote">Anyway today I got stuck because I could not get the tranny separated from the motor. My manual says that I only have to remove the upper starter bolt. </TD></TR></TABLE>
what manual do you have? there are quite a few more bolts than just the starter bolts. u know that right or am i misreading the post?
Old Jul 21, 2004 | 11:52 PM
DrewDown's Avatar
Yeah I know that. I have a Haynes manual. I may have misinterpreted it and thought it was the upper that needed to be removed. Either way I just spaced and couldnt figure out why I couldnt separate it. I'm pretty sure that was my problem, but Ill figure it out in the morning.
I just posted this because it was bugging me and I wanted some confirmation that it was where I had messed up
Old Jul 22, 2004 | 04:58 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (DrewDown)
Just remove the starter completely.
Old Jul 22, 2004 | 05:42 AM
littlemracura's Avatar
Default Re: (PatrickGSR94)
Man....just go here...and read your Haynes a little more carefully as well...
http://www.c-speedracing.com/h...h.php
nitewolf
Oct 8, 2014 06:37 PM
Grampy Mike
Dec 30, 2010 11:20 AM
JohnWayne
Aug 3, 2005 07:10 PM
Audi RS4
Nov 9, 2003 07:01 PM
ransack
10
Oct 4, 2002 11:01 AM
