vtec engage and power falls flate
Old Jul 21, 2004 | 10:12 PM
VAAJ's Avatar
Default vtec engage and power falls flate
ok, here are the mods & engine;
B16 converted to OBD1
Stock P30 ECU
Type R head
CTR piston standard
Skunk2 stage 2 cams
skunk2 valve spring
mugen 2 layer HG
Stock injectors
heres the problem,
just before vtec engage I can feel the powerband dip as if it choke. this dip of power is really noticeable. this only happen during 3rd gear and 5th gear.
The P30 ecu does not throw any CEL, but when i try on a stock P28 ecu i get the ELD Code 20. Sometime during idle the engine would shut off by itself, this happen randomly.
if you have incounter similiar conflict, please feel free to explain your experience and what you did to solve it.
Old Jul 21, 2004 | 10:52 PM
hahagasdcrx's Avatar
Default Re: vtec engage and power falls flate (VAAJ)
my friend has the same problem. Turns out its all because his P30 was for an automatic. Switched to a chipped P28 and no problems.
Old Jul 26, 2004 | 10:12 PM
VAAJ's Avatar
Default Re: vtec engage and power falls flate (hahagasdcrx)
Fixed the dam problem! TPS sensor was off of spec. Set it back to spec. God dam these cams pull hard!!!!!!!!!
Sub|ime
Sep 28, 2010 02:34 AM
Sub|ime
Sep 27, 2010 04:22 PM
mac_24_seven
Aug 30, 2006 10:46 AM
cinq
Oct 10, 2003 05:38 PM
TEGPOWER44
Dec 16, 2002 03:14 PM
