whats a good temp for EGT probe to read at idle and wot?
Old Jul 21, 2004 | 09:00 PM
Herminator's Avatar
Default whats a good temp for EGT probe to read at idle and wot?
did a search and got nothing. i suck at this stuff sorry.
Old Jul 21, 2004 | 10:25 PM
99AccordTurbo's Avatar
Default Re: whats a good temp for EGT probe to read at idle and wot? (Herminator)
Depends were the probe is installed!
Old Jul 21, 2004 | 10:49 PM
ATS*Mark's Avatar
OG triple OG
Default Re: whats a good temp for EGT probe to read at idle and wot? (99AccordTurbo)
mines right after the turbo , i red 4-6 idle . and 12 at 80 mph , doesnt get much above that , maybe 14 at wot
Old Jul 21, 2004 | 10:50 PM
pngfolife's Avatar
Default Re: whats a good temp for EGT probe to read at idle and wot? (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">mines right after the turbo , i red 4-6 idle . and 12 at 80 mph , doesnt get much above that , maybe 14 at wot</TD></TR></TABLE>
Farenheit right?
Old Jul 21, 2004 | 10:56 PM
ATS*Mark's Avatar
OG triple OG
Default Re: whats a good temp for EGT probe to read at idle and wot? (pngfolife)
yes , and thats x100
Old Jul 21, 2004 | 11:51 PM
djfob's Avatar
mines about 600 idle and never goes over 1200
Old Jul 22, 2004 | 05:01 AM
Griffin@Camtech's Avatar
I am not 100% sure but I thought EGTs should be from 1400 to 1600
Old Jul 22, 2004 | 05:36 AM
underpressure02's Avatar
At idle my egt temp needle does not move. WOT the most I ever hit is 800C.
Old Jul 22, 2004 | 08:12 AM
XiiiXiii's Avatar
Herman was posting for me last night.
Here's what i got :
Vortech Super Charger (10lb kit)
EGT probe is placed 2-3 inches from the engine on the header (cylinder #3).
I've heard 1400 degree's is bad? Is this right?
here's the funny thing, under WOT from 5th gear cruising at 75mph it goes from 1400ish and starts to decrease. In otherwords the temp starts to go down as I put a load on it.
Temp also goes down if I let go of the gas.
Weird thing (the thing that bugs me most) is that I'm just cruising at 75mph 5th gear (about 4500rpm) and my EGT starts climing towards 1400 and maybe beyond (i try to keep it under 1400 cuz i've heard somewhere before that 1400 was bad). It just seems strange to me that under minimal load, and just cruising the EGT starts to climb high. If I push the pedal harder (and go faster than cruising speed) the EGT starts to fall down slowly. If i let go of gas completly the gauge will drop to 1100 range very quickly.
This kind of sucks because I can't just cruise on the freeway?
Should I be worried? Is 1400 a bad numer or am I missinformed? (it was something along the lines of 1400 = **** starts to melt on a honda block).
If you understood what I said and have any information for me it's much apreciated.
-Michael
Old Jul 22, 2004 | 09:53 AM
Wo-Nelly's Avatar
Default Re: whats a good temp for EGT probe to read at idle and wot? (XiiiXiii)
I think your tuner/or you just leaned it out when your off boost so you save on gas.
zakl
Jun 22, 2017 11:10 AM
Paprika
May 8, 2007 03:18 PM
k1dfreeze
22
Aug 19, 2005 12:03 PM
EF8_SiR
Sep 18, 2003 02:31 PM
