Excessive Blow-by - Built 83mm block
Old Jul 21, 2004 | 02:23 PM
Turboteggy's Avatar
Default Excessive Blow-by - Built 83mm block
Setup is a 83mm Bensons sleeved, Earl Laskey assembled LS block. Eagle rods, CP Pistons and rings, ACL bearings, and new oil/water pump/timing belt.
Approx 2000 Kilometers (1250 miles). No boost whatsoever for the first 800K then 15 PSI since with Hondata and 720's.
I removed the PCV valve and plugged the bung from the manifold, so the block can breathe under boost.
Also, the valve cover breather is a hose running to the ground.
At idle, I can see the blow-by coming out the valve cover breather, and after a hard run, my hood has a fresh coating of "rustproofing: LOL (it comes out the hole where the PCV Valve was originally installed and blows right up to the hood.
Is this normal?
Old Jul 21, 2004 | 03:01 PM
Mase's Avatar
Default Re: Excessive Blow-by - Built 83mm block (Turboteggy)
might wanna do a compression check, and check with whoever tuned it and make sure they didnt dick up the tune.
Old Jul 21, 2004 | 07:44 PM
u2civic1's Avatar
was the car tuned rite after u got the block or did u wait 500miles and then tune?
Old Jul 22, 2004 | 02:10 AM
808 NA1's Avatar
Put back the pcv. I can almost guarantee you that the crankcase blowby will go away.
Old Jul 22, 2004 | 05:51 AM
Slick GS-R's Avatar
Default Re: Excessive Blow-by - Built 83mm block (808DB8)
did you read this? https://honda-tech.com/zerothread?id=878397
Old Jul 22, 2004 | 07:33 AM
Turboteggy's Avatar
Default Re: Excessive Blow-by - Built 83mm block (Slick GS-R)
Absolutley. He built my motor. I started it up with a wideband, and it was bouncing from 14.5-14.9.
I drove it like that with no boost for 500 miles (800K) and then tuned it to 15 PSI. There was hardly no blow-by at all on the dyno, but it's been getting worse and worse by the week since.
Not a happy camper.
Old Jul 22, 2004 | 07:38 AM
FredoSP's Avatar
whats ur compression looking like?
Old Jul 22, 2004 | 09:16 AM
Slick GS-R's Avatar
if you read the whole thread ... earl said to tune IMMEDIATELY! not to wait X amount of miles. read the thread again
Old Jul 22, 2004 | 09:31 AM
earl's Avatar
do a leakdown and let me know the results. if it is smoking, a ring or piston could be hurt. tuning first before break in is so critical, even without boosting. too rich can be as bad as too lean also.
Old Jul 22, 2004 | 09:33 AM
spark plugs.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboteggy &raquo;</TD></TR><TR><TD CLASS="quote">Setup is a 83mm Bensons sleeved, Earl Laskey assembled LS block. Eagle rods, CP Pistons and rings, ACL bearings, and new oil/water pump/timing belt.
Is this normal? </TD></TR></TABLE>
man o man....i did the EXACT same thing even down to running to hose to the ground to hide the smoke. it's gonna get worse...MUCH MUCH WORSE. it was my rings and i ran it until they just gave out and the car wouldn't turn over.
Old Jul 24, 2004 | 10:12 AM
Turboteggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slick GS-R &raquo;</TD></TR><TR><TD CLASS="quote">if you read the whole thread ... earl said to tune IMMEDIATELY! not to wait X amount of miles. read the thread again</TD></TR></TABLE>
The tune was fine. I had a wideband on it since start-up. Numbers were perfect.
After the dyno, numbers were pretty much identical, and under WOT boost, it hangs around 10.8-11.4.
Head comes off this weekend. We'll see what's going on.
Old Jul 24, 2004 | 10:27 AM
B18C1CYA's Avatar
i would check compression first and then leak down befor you go riping things apart.
Old Jul 24, 2004 | 09:50 PM
808 NA1's Avatar
Did you remove the pcv after, or did you never have it since the beginning?
Old Jul 25, 2004 | 08:14 AM
Turboteggy's Avatar
It was hooked up at first, because there was never any boost to the motor.
It was disconnected on Dyno day.
Old Jul 25, 2004 | 09:14 AM
808 NA1's Avatar
Why dont you just try putting it back and see what happens. It cant hurt.
blackeg
Apr 5, 2011 04:48 AM
lll_fusion_lll
May 20, 2010 05:55 AM
kielcivic
Jun 11, 2009 02:57 PM
bseries_beast
May 9, 2008 10:05 AM
