Serious Idle Problem
Old Jul 21, 2004 | 02:17 PM
Dullycam's Avatar
Default Serious Idle Problem
I just got done building my motor and bolted it in the car.
The motor idle's from 1500 to 2500 rpm's won't go any lower it will run about 2k for a minute and then just drop down then the idle goes back up sometimes it stalls i have no clue whats wrong. I have a brand new idle control valve from honda is their any otherr sensors that could be causing this? I hooked up my EMS and every sensor looked good it's built for turbo but breaking the motor in N/A.
Any suggestions would be appericiated "I wanna drive my car"
Thanks
Old Jul 21, 2004 | 02:34 PM
greaseball's Avatar
Default Re: Serious Idle Problem (Dullycam)
fast idle valve, intake leak, could be a lot of things. i would run the car and spray some carb cleaner on the intake mani where it bolts up to the head. if your car stalls, then you got a leak. check and clean your ficv also. good luck.
followthadollar
Apr 20, 2010 06:23 PM
jdmintegra18
May 27, 2009 04:30 AM
Tytank7
May 8, 2008 11:29 AM
redferio
12
Nov 5, 2006 06:00 PM
94SHOWLS
Feb 17, 2005 12:31 PM
