High Idle/Help Needed
Old May 21, 2009 | 04:21 PM
jdmintegra18's Avatar
Default High Idle/Help Needed
whats up fellas i got my turbo gsr tuned and have been driving it for awhile and its been fine but its devloped a high idle...in the morning when i start my car it idles at 3k which i know it supposed to idle high when its cold but not that high once it warms up it comes down to 1500 but my wideband says its like 15.0 16.0 which is pushin lean now this is at idle...when driving the car it runs fine and dosent run lean...ive checked everything i cant find a leak anywhere...i figured you guys may know something i dont...thanks in advance
Old May 21, 2009 | 05:01 PM
SilverEk3dr's Avatar
Default Re: High Idle/Help Needed
Prob got an idle valve sticking. Clean it out and see what happens.
Old May 22, 2009 | 05:20 PM
ok so it wasent the idle control vavle..ive checked every sensor and every vacum nipple..the intake manifoldit tight.. i took the charge pipe off and put my hand over the tb and the motor shut right off...im stumped...can it be in the tune anyways..my tuner says its a small vaccum leak but i unhooked the blowoff vacumm line and left it open and it picked up 500 rpm..so it has to be something else to make it idle so high...any ideas guys
Old May 26, 2009 | 02:23 AM
DreTec's Avatar
It's strange how it's come from nowhere. A map shouldn't just change.
I'm not sure what age your engine is so not sure if it has the FITV (Fast idle thermo valve), but if it has, take that to pieces and clear it out.
It does sound like the symptoms of a vacuum leak... does it hunt at all or are the revs just steady all the time? Could a pipe of split anywhere around the inlet mani?
Old May 26, 2009 | 05:50 AM
dpetro1's Avatar
im having the same issue. almost positive its a vac leak even though im having trouble finding it.
do you have a boost/vac gauge? ive noticed that im only getting 20" at warm idle when i normally get 22", further indicating a leak
Old May 26, 2009 | 03:07 PM
turned out to be the plastic had came unscrewed in the fast idle vavle cause air to leak nuy all the time..i cleaned it all up and tightend back down and it works fine
Old May 27, 2009 | 04:30 AM
dpetro1's Avatar
that will do it..too bad i have no fitv. o well back to hunting for my leak
TearSDMF89dx
Jan 3, 2012 04:31 AM
joelmatt89
15
Nov 4, 2009 05:27 PM
manyakiexpi
Feb 18, 2006 11:45 AM
virusiidx
Jan 18, 2005 07:21 AM
boostin4drcivic
Feb 1, 2004 09:15 PM
