Help. Del sol clutch problems
Old Jul 21, 2004 | 10:41 AM
hondadelsol.co.uk's Avatar
Default Help. Del sol clutch problems
the other day i suddenly found it hard to change gears, a little extra force was needed and a slight crunch was then heard. so i checked the clutch master cylinder which i found to be leaking.
so today i have replaced this with a brand new unit. i have fully bled this system and i am certain that there is no air in the system.
but now the gears will not engage at all.
i can feel the slave unit moving inside the rubber boot (front of engine near radiator) when the clutch pedal is pressed but the gear stick will not move.
drlagares
18
May 30, 2015 03:46 PM
509delsol
Apr 22, 2012 01:54 PM
94SolMan
Apr 29, 2009 12:07 PM
yaba3800
Sep 14, 2008 02:57 PM
PatrickGSR94
17
Aug 3, 2006 08:36 PM
