What is the proper numbers for compression in a B16?
Old Jul 21, 2004 | 10:16 AM
prodigalson's Avatar
Default What compression numbers for a B16?
I'm looking at purchasing a Del Sol VTEC (115K miles) and I am going to get the compression checked. What is the normal compression for a healthy B16 engine?
Modified by prodigalson at 2:28 PM 7/21/2004
Old Jul 21, 2004 | 10:23 AM
Spade's Avatar
Default Re: What compression numbers for a B16? (prodigalson)
you'd want about 150, IMO.
Old Jul 21, 2004 | 10:38 AM
delScho's Avatar
Default Re: What compression numbers for a B16? (Spade)
I wouldn't use the word "want". He'd want them all sitting at 200 or higher with no one cylinder varying by more than 10 psi from the others. 150 just seems a little low to me. My sister's Accord with an H23A1 and 111k on it just compressed 215-220 on every cylinder last weekend. So I definitely see a healthy B16 churning out 200+.
Old Jul 21, 2004 | 10:42 AM
Civic92Turbo's Avatar
do you saying 200+ is good right...cau i am about to do mine.cause it feel sicks as hell right now
Old Jul 21, 2004 | 11:54 AM
delScho's Avatar
Default Re: (Civic92Turbo)
I'd like to hear Spade's thoughts on it just in case I'm way off base. It's been known to happen once or twice. But yeah, I think that 200+ is really where you want to be. Not that 185 would be bad, it's mostly the deviation that you should be worried about where one cylinder is really off (more than 10 psi difference).
Old Jul 21, 2004 | 12:26 PM
eg2rs's Avatar
Default Re: (delScho)
Helm's for 94 del sol
Nominal 220 psi
Minimum 135 psi
max variation 28 psi
Old Jul 23, 2004 | 01:47 PM
thankx EG2RS
Old Jul 23, 2004 | 01:59 PM
Spade's Avatar
My assumption of an engine that is beat on with that many miles would be at about 150 or so.
I should have stated you want higher than 150. What the heck was I thinking?
Old Jul 23, 2004 | 04:49 PM
eg2rs's Avatar
Default Re: (Spade)
i beat the hell out of my car on a daily basis. I bought it new and now it has 138,000. my compression is 185 to 190 across the board. good luck hope you get a good ride!
airslammedcivic2
Apr 8, 2010 12:18 AM
callmetree19
Dec 1, 2008 10:17 PM
CaptivaBlue
May 4, 2004 01:34 PM
lothian110
Oct 28, 2003 09:24 PM
lothian110
