help me please oil leak
Old Jul 20, 2004 | 10:39 PM
TURBOFTW's Avatar
Default help me please oil leak
ls bottom
gsr head:
Ok on the intake cam seal on the timing belt side i cannot seem to get it to stop leaking i have yet to replace the seal i put it together without any sealent (sp?) and it leaked so i tore it apart again and put some high temp black silicone and it still is leaking also the cam cap that is closest to the cam gear is a little worn nothing major as far as i can tell, all the rest are fine could this cause it? i also noticed that while the motor is running i watch the intake cam gear ( aem) and it doesnt look to be spinning completely true, but the exhuast is spinning perfect.... please and help
Old Jul 21, 2004 | 03:34 AM
93H22ACX's Avatar
Default Re: help me please oil leak (h22dude)
use honda bond gasket maker not silicone....as for the cam not spinning....best thing to do is take the came out to look at the camshaft and caps to see if anything is interfering with the spinning of the cam. did you lube the cams before installation?
Old Jul 21, 2004 | 06:34 AM
TURBOFTW's Avatar
Default Re: help me please oil leak (93H22ACX)
the cam shaft spins free no scores on the shaft or anything but when the motor is running u can see the cam gear it looks to be bent....
Old Jul 21, 2004 | 06:35 AM
93H22ACX's Avatar
put your stock on on and see if it spins freely. if it does than its your gears if it doesnt maybe your camshaft
Old Jul 21, 2004 | 06:38 AM
TURBOFTW's Avatar
I got to go find a stock one i was reading that if it was in fact the cam that is bent it wouldnt spin free and hardly even spin? also the cap cap journal did have some minor wear nothing really bad and it was only just this one cap...
Old Jul 21, 2004 | 06:54 AM
93H22ACX's Avatar
what cams do you have?
Old Jul 21, 2004 | 06:56 AM
TURBOFTW's Avatar
itr right now....
Old Jul 21, 2004 | 06:59 AM
TURBOFTW's Avatar
Since i dont have the stock cam gear is there a difference between the exhaust and intake cam gear?
Old Jul 21, 2004 | 07:00 AM
93H22ACX's Avatar
cam gears...not that i'm a aware of
Old Jul 21, 2004 | 07:06 AM
TURBOFTW's Avatar
i think im a put my exhaust cam hear on the intake side and vice versa and if the cam gear still is not spinning stright then i KNOW for a fact its the gear
Old Jul 21, 2004 | 07:07 AM
93H22ACX's Avatar
let me know
Old Jul 21, 2004 | 07:49 AM
TURBOFTW's Avatar
this is what im going to do replace both seals use some hondabond and switch the gears to the opposite sided
Old Jul 21, 2004 | 10:38 AM
TURBOFTW's Avatar
anyone else with any ideas?
crxstylin
Mar 20, 2008 12:53 PM
nutball72
Aug 21, 2006 01:47 PM
TURBOFTW
Jul 21, 2004 01:37 PM
TURBOFTW
Jul 20, 2004 10:50 PM
