How lean is too lean?
your a little lean on the upper rpms. i like to keep it at 13:1 or 13.1:1 throughout. There is enough safety margin in there to compensate for different weather conditions. The 13.6:1 at the top is pushing the safety limit. If it gets real cold out and you push it hard it could possibly lean out. from 4.5-5.5k you could lean it out a tad, otherwise graph looks solid
Keep it under 14:1. Its alot safer..
The weather really effects the A/F.
The car will run abit richer in cooler weather.
and a little extra fuel really doesnt cost u alot of horse.
OK, Help me out here.. According to this graph, I thought lean was closer to the top. After all, the tech did set the V-AFC from -5% - 8% on the second run.
Torque says richer in cold weather, Fast94gsr says leaner in the cold.
and... 13.6:1 is "pushing the safety limit" ?
I'm seeing conflicting info here.
A little help?
thanks!
A little help?
thanks!
keep it a little lean in the bottom rpm range and the higher the rpms go the closer you want to be around 13:1...you should be around 13:1 at 4500rpm or so...have the botton rpm range rich will actually slow the car a little bit
dude you misinterpret what i'm saying let me clarify..
13.6:1 is pretty lean for the upper high rpms. when it gets colder your car will lean out even more to a 14.something :1 af ratio and that is unsafe. so richen it up at the upper rpms.
at the lower rpms your running too rich, keep the rpm range consistent with 13.1 throughout. 13.1:1 has been proven to be the best af ratio to go with. hope that clears things up.
brookliner7
Feb 28, 2006 11:21 PM
cruzersi99
Dec 8, 2002 01:59 PM
