my teg rides like S**T!!.... need advise
well here it is, every since i dropped my integra its been riding like s**t in the freeways. It rides all "wabbale". The steering wheel wont stay still if i let go. Can it be ALIGNMENT?? need advise please. it might sound stupid to some of u guys out there but i really need help. thanx guys
my suspension set up= skunk2/tokico blues.
Who installed the suspension? you? I would guess it's alignment. However, you might want to make sure that your wheels are balanced and the lug nuts are tightened too.
to check if it's alignment jerk the wheel to one side and if it returns quickly then your alignment should be good. Do it to both sides. This does sound like an alignment issue though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G1_TEGGY »</TD></TR><TR><TD CLASS="quote">any time you let go of the wheel and your car does not run in the direction you had it in before you let go, that's alignment</TD></TR></TABLE>
yup, thats exactly how it is. so thats was causing it to ride like crap?? u kno " wabbale"???
My car did the same thing when i lowered it. I had a couple problems. First, the stock shocks bleed out the oil.. so i got some kyb gas shocks. Good stuff, this made the ride smoother. My car was still shaking a bit so i checked my alignment. And yes, my alignment was off, so i got that fixed. After that, the ride was good but i finished it off with some camber kits that way the rides wear down equally instead of wearing down on the edges.
Everything is great now.
I bet its your alignment.
hey, thanx for all ur replies guys. ill be getting an alignment next week n ill let u u guys kno how it turns out.
Historyg
Dec 22, 2007 05:42 PM
