steering shaking
Old Oct 5, 2007 | 07:15 AM
Jdmls's Avatar
Default steering shaking
Aight fellas i recently bought new wheels for my teg and bought tein basic damper kit for my ride. At about 60 mph and up, the steering wheel shakes slightly, i dont if its because the suspension is lot more stiff so the car feels more rugged. Any advice as to where to start checking for this problem?
Old Oct 5, 2007 | 07:20 AM
dickdragon's Avatar
1st get your wheels/tires rebalanced. it's sounds to only be that minor. if that doesn't work check products for defects. especially tires or bent wheels.
Old Oct 5, 2007 | 08:14 AM
DC2_117's Avatar
Default Re: (dickdragon)
Front end alignment and adjust of chamber might be the issue. Correct me if I am wrong but when ever you change out your suspension/ chamber you should always get a alignment redone. It also might be the wheels balanced ^^
Old Oct 5, 2007 | 11:08 AM
jetblackhybrid's Avatar
Default Re: (DC2_117)
in oreder, check
wheel/tire balance
bent wheel
allignment
Old Oct 6, 2007 | 10:06 PM
Jdmls's Avatar
Default Re: (jetblackhybrid)
Thanks for the input ill let you guys what is the outcome.
Old Oct 7, 2007 | 12:24 AM
suzawa94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_117 &raquo;</TD></TR><TR><TD CLASS="quote">Front end alignment and adjust of chamber might be the issue. Correct me if I am wrong but when ever you change out your suspension/ chamber you should always get a alignment redone. It also might be the wheels balanced ^^</TD></TR></TABLE>
bad alignment/camber will not cause a steering wheel shimmy.
Old Oct 7, 2007 | 12:28 AM
suzawa94's Avatar
Default Re: steering shaking (Jdmls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmls &raquo;</TD></TR><TR><TD CLASS="quote">Aight fellas i recently bought new wheels for my teg and bought tein basic damper kit for my ride. At about 60 mph and up, the steering wheel shakes slightly, i dont if its because the suspension is lot more stiff so the car feels more rugged. Any advice as to where to start checking for this problem? </TD></TR></TABLE>
first off i would suspect an out of balance tire. if your wheel is bent, the tire balancer will definatly let u know. stiffness of the suspension will not cause a steering wheel vibration. vibration in a car is caused with a component that is rotating. steering rack, rotor, axle, hub and bearings and wheels/tires will cause a steering vibration.
Old Oct 8, 2007 | 05:54 PM
Jdmls's Avatar
Yo fellas thanks for info got my wheel balanced all four of them and i tested the car on the freeway and it just needed wheel balancing. It turns out the tire shop that initially put wheels on have a bad reputation. The tire shop that i went to have wheels rebalanced were telling they get a lot of customers complaining about that tire shop.If you in Richmond Hill,Queens i dont recommend you going to the tire shop on Linden blvd right off the van wyck expressway service road . I would recommend them
Old Oct 8, 2007 | 08:26 PM
Arsenal's Avatar
Default Re: (Jdmls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmls &raquo;</TD></TR><TR><TD CLASS="quote">.If you in Richmond Hill,Queens i dont recommend you going to the tire shop on Linden blvd right off the van wyck expressway service road . I would recommend them</TD></TR></TABLE>
Might want to rephrase your sentance. You don't recommend the shop, then you do!
mugenpowered
26
Jun 8, 2008 01:15 PM
H0ndas g0 Vr00m
Honda Civic (2001 - 2005)
Oct 13, 2007 02:48 PM
h22pwr
Apr 12, 2006 06:46 AM
Jer'rome
Aug 12, 2003 08:24 PM
derelikt
15
Feb 21, 2002 12:35 PM
