SRS Light
Old Jul 20, 2004 | 09:32 AM
kjf1234's Avatar
Default SRS Light
Hey my srs light has been on ever since i had my alternator replaced my car died twice anyways got it all fixed up but the SRS light is still on and need to know how to reset it i have a 95 civic coupe SI i am from canada its a Automatic
Thanks a lot
hope this is a easy fix
Old Jul 20, 2004 | 09:34 AM
handa's Avatar
Default Re: SRS Light (kjf1234)
i've never have an SRS light on my car yet, but i think maybe resetting the ECU might do the trick.
Old Jul 20, 2004 | 09:41 AM
kjf1234's Avatar
Default Re: SRS Light (handa)
I have tried that already took the fuse out and did the procedure but no luck is there another way to reset the system
Old Jul 20, 2004 | 09:42 AM
Grimm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">i've never have an SRS light on my car yet, but i think maybe resetting the ECU might do the trick.</TD></TR></TABLE>
nope it's a different system.
SEARCH
Do a search it invloves shorting out the SRS system similar to the ECU, but the connector is on the drivers side.
Again do a search this topic has been covered
Old Jul 20, 2004 | 09:44 AM
DaX's Avatar
DaX
Loved
Community Favorite
After installing my TekniqAuto snap off steering wheel, I got the annoying SRS light. I just pulled the bulb out of my cluster. No more annoying light.
Old Jul 20, 2004 | 09:47 AM
Grimm's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">After installing my TekniqAuto snap off steering wheel, I got the annoying SRS light. I just pulled the bulb out of my cluster. No more annoying light.</TD></TR></TABLE>
you will fail inspection if they notice that...
Old Jul 20, 2004 | 09:49 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">
you will fail inspection if they notice that...</TD></TR></TABLE>
Not in GA...
Old Jul 20, 2004 | 10:00 AM
Grimm's Avatar
Default Re: (DaX)
your very lucky.... here in nj if a light dosen't light up on your dash at initial startup you fail, and if you got a light on while driving you fail...
NJ sucks
jhaag115
Aug 8, 2009 12:41 AM
jdmrida
Nov 21, 2008 08:58 AM
undercoversi
10
Oct 4, 2004 11:18 AM
Brakiss
Aug 17, 2004 01:00 AM
saanemon
May 28, 2003 10:12 PM
