ECU Problems
Old Jul 20, 2004 | 09:04 AM
dohcdelsol93's Avatar
Default ECU Problems
I just did a b18b swap in my 93 Del Sol SI and the check engine light is on. I pulled the plug from the boot above the ECU to give me the codes but when I jump the plug and turn key to on position the check engine light will not blink. Could I have a bad ECU?
Old Jul 20, 2004 | 09:24 AM
Tyree's Avatar
Default Re: ECU Problems (dohcdelsol93)
did you jump the right wire?
Old Jul 20, 2004 | 09:27 AM
menkio's Avatar
Default Re: ECU Problems (WatsUpDOHC)
and how did you jump the wire?......
Old Jul 20, 2004 | 10:00 AM
Default Re: ECU Problems (DewMota)
used a paper clip and jumped the 2 hole plug that sits above the ecu (that sits inside green rubber boot beside 3 hole plug) I thought that maybe the paper clip was not getting a good connection so I tried using a spliced piece of wire to no avail. and I am using a p75 obd1 ecu on a 94 ls and it is set up for my ecu(all obd 1) but I think the ecu might be chipped, could that cause this? If so someone please hook me up with a bone stock p75 obd1 ecu from a m/t teggie.
Old Jul 20, 2004 | 10:28 AM
3.3.3's Avatar
the car needs to be running while the check engine light is on. does you get the CEL right after it fires up?
Old Jul 20, 2004 | 11:01 AM
Default Re: ECU Problems (3 3 3)
Yes, the cell light is on when I start the car but I thought you could damage the ecm if you started the car with the plug jumped.
94whitegsi
Aug 4, 2006 07:22 PM
dohcdelsol93
Jul 19, 2004 12:03 PM
phat_gsr98
Jul 13, 2004 05:40 AM
ludatic
Nov 2, 2003 10:46 PM
gocivicgo
Aug 11, 2003 03:43 PM
