whats wrong with my AC
Old Jul 19, 2004 | 05:28 PM
grizoove's Avatar
Default whats wrong with my AC
Well, here is the story as short and sweet as I can put it.
car: '94 integra ls sedan 149000 miles
problem: AC blows "coolish" but never chills in the daytime heat here in Dallas
symptoms: *While driving with AC on a draining-type sound comes from the front right. *Checked and filled freon late in the week, was cool for a few days. Filled coolant again today (7/19).
So what is most likely wrong? freon leak? I dont know squat about AC systems. TIA
Old Jul 19, 2004 | 06:15 PM
tC_Dragon's Avatar
Default Re: whats wrong with my AC (grizoove)
i don't know what it is, but my buddy integobsession had that same wierd sound in his old 01 gsr as well. it sounds like water is running to the back of a container or something huh?
Oh, as for ur AC, i'd check the lines and see if you have a leak somewhere. It should be cold.
Old Jul 19, 2004 | 07:05 PM
grizoove's Avatar
Default Re: whats wrong with my AC (pdcdragon)
yeah that is a pretty accurate description of the sound. I will check the lines tommarrow. anyone have any other ideas?
Old Jul 20, 2004 | 05:05 PM
red95integ's Avatar
When you drive does your ac compresser make a loud/unusaul sound? If you do have a leak you can buy a can of **** that is soposta seal the leak. It worked on my caddy i had
Old Jul 20, 2004 | 10:49 PM
PnX-R's Avatar
I can't remember exactly but, the 94 Tegs have a service bulletin out that shows the location of a R134a leak which is by radiator. To find out more about this, I'd ask a tech that works at Acura for the info or stop on in myself.
Nihsnek
Apr 29, 2010 07:42 AM
CivicSD
Aug 20, 2007 08:40 AM
crazyteg95
Oct 8, 2004 10:37 AM
