ignition coil install need help?
Old Jul 19, 2004 | 04:56 PM
civicmp's Avatar
Default ignition coil install need help?
I got the distributor cap off but how do i get the rest off to get to the ignition coil?
Old Jul 19, 2004 | 06:28 PM
-faded-'s Avatar
Default Re: ignition coil install need help? (civicmp)
next you have to remove the rotor. there is one small screw on the back of it. you have to turn the key a little to spin it to get the screw into view. after that there is 2 bolts on top that hold the coil in. remove those, remove the wires, and your set. hope that helps
Redline130's Avatar
There should be screws holding it to the distributor housing.
Jeremy Dunn
Jun 20, 2017 11:49 AM
Hybrid Invasion
Nov 25, 2007 11:50 PM
DredwerkZ
Apr 19, 2004 05:21 AM
jazz215
19
Aug 17, 2003 10:25 PM
Utilitarian
Jul 14, 2003 04:53 AM
