Engine Upgrade Christmas List..need vavletrain help
So I'm getting together my Christmas list (I'm hoping to get maybe one or two of these things). I'm going to eventually be doing a cam and valvetrain upgrade hopefully next summer but I want to start getting everything I will need together. I don't want to skimp on anything. So far I know I need:
1 CTR intake cam
1 ITR Exhaust cam
2 Cam gears
Field VTEC Controller
But I'm not sure about the following:
Field VTEC Controller Harness (what the heck does this do)?
Valvetrain...What all do I need? Inner/outer springs, valves, retainers? I'm
not an expert on this. Should I go with a complete JUN setup? Will that go with
OEM cams or should I get all the OEM parts individually (can somebody list these)?
Any help would be greatly appreciated!
1 CTR intake cam
1 ITR Exhaust cam
2 Cam gears
are you going to raise your redline with the ctr cams? if so then upgrade your valvetrain, but if not then stock valvetrain is fine
you'll also need a new headgasket (mugen or spoon comes to mind to raise compression a little)
i'd go with the full type-r setup myself and rev up to 8400...
honda reliability !
good stuff ......
Titanium Retainers
Stainless Steel Valves
Dual Valve Springs
You can get Bronze Valve guides but you don't need em
[Modified by immortal, 11:26 AM 11/25/2001]
honda reliability !
good stuff ......
Titanium Retainers
Dual Valve Springs
