Alarm options
Proximity. Let's the thief know the car's not going to be happy. Also, you can leave your windows down to run into a store.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 »</TD></TR><TR><TD CLASS="quote">depending on car.. i just put it under the armrest. </TD></TR></TABLE>
Where would I put it if I have a 97 Civic?
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictrbo95 »</TD></TR><TR><TD CLASS="quote">I would use the break glass sensor. It is more important.</TD></TR></TABLE>
The prox. will also "see" the glass brakeing, and a glass sensor can't see the car being slim jimed, also, a little milar and ceramic, and i can remove the glass without so much as a peep.
94
94
Which one of the 2 will give you more false alarms? I was thinking about this too, and got myself a glass sensor in the end. I don't want a mailman setting off my alarm...nor my cat that likes to hide under cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odessa »</TD></TR><TR><TD CLASS="quote">Which one of the 2 will give you more false alarms? I was thinking about this too, and got myself a glass sensor in the end. I don't want a mailman setting off my alarm...nor my cat that likes to hide under cars.</TD></TR></TABLE>
Where did you but your sensor at and how much was it?
proxy sensor = made for convertibles. the microwaves used in proxy sensors do not go through metal so if you have a non-convert, it will get bounced off the roof and all over the interior of the cab and cause all sorts of falses. If you have an hr to dick around with the internal and external adjustments on a proxy..get it. If not then get a glass break and relax with a beer after you install it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSP »</TD></TR><TR><TD CLASS="quote">proxy sensor = made for convertibles. the microwaves used in proxy sensors do not go through metal so if you have a non-convert, it will get bounced off the roof and all over the interior of the cab and cause all sorts of falses. If you have an hr to dick around with the internal and external adjustments on a proxy..get it. If not then get a glass break and relax with a beer after you install it.</TD></TR></TABLE>
Brraaahahahahahahah not so. 94
alacard
Audio / Security / Video
10
Dec 13, 2006 09:56 PM
02 accord
Oct 14, 2006 08:32 AM
