Is shock sensor bypassed when car is remotely started?
When a car is remotely started (alarm still armed), is the shock sensor bypassed so the vibrations from the engine don't set off the alarm ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misanthropist »</TD></TR><TR><TD CLASS="quote">Yes, everything but pinswitches are bypassed iirc.</TD></TR></TABLE> this is not always the case. it usually is correct on all in one units but if you have an alarm with add on start you will usually need to wire up relays to bypass sensor inputs during the remote start process.dei also has another method of bypassing the sensor also but i cant remember how to do it. maybe fcm does.
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote"> this is not always the case. it usually is correct on all in one units but if you have an alarm with add on start you will usually need to wire up relays to bypass sensor inputs during the remote start process.dei also has another method of bypassing the sensor also but i cant remember how to do it. maybe fcm does.</TD></TR></TABLE>
Most add on units if not all have a neg or pos trigger output during the remote start process. And a relay is all thats needed to bypass what ever you want.
DRKSol
Audio / Security / Video
May 4, 2007 08:17 PM
