does honing mess up the way your engine seals?
Old Jul 18, 2004 | 08:58 PM
Red_EM1's Avatar
Default does honing mess up the way your engine seals?
i would think that honing would make your cylinders a slight bit bigger and your piston rings wouldnt seal as well messing up your compression. is this the case or does it not really mess it up?
Old Jul 18, 2004 | 09:11 PM
RenoRacing's Avatar
Default Re: does honing mess up the way your engine seals? (Red_EM1)
Well, honing is usually done prior to assembly of a rebuilt motor, and in turn before gapping the rings(which should be new). but yes, your thinking is correct. A hone job "can" make a bore larger but usually is just a simple removing of the glazed surface so that the rings will seal. The diameter increase by honing is a tiny amount though, not sure on the exact number but i can't imagine most hone jobs remove more than about .05mm.
Old Jul 18, 2004 | 09:20 PM
Suprdave's Avatar
They gotta take off 3 thou minimum usually...mess up your clearances...
Old Jul 26, 2004 | 07:17 PM
Sport_Injected's Avatar
Default Re: does honing mess up the way your engine seals? (Suprdave)
so whats the answer? it does mess it up or it doesnt?
Paul Kane
K Series
Jun 8, 2015 05:49 PM
eswaroop
Sep 20, 2010 01:48 AM
lke2drvgsr
Apr 29, 2004 05:48 PM
Sliced Beard
Jan 22, 2004 06:55 PM
