Reverse mini me (a6 head z6 bottom) with obd1 distributor and ignition timing
does anyone know where to mount the distro for a reverse minime?
i'm using my a6 head for a while becauce the z6 one i bought has bent valves and i've got the head on; timing belt taken care of but i dont know where to set the timing on the distro.
only the top hole lines up so should i put the bolt in there and play with it or rotate the distro or what.
i know the obd1 z6 distro is rotated and the obd0 a6 distro is sitting straight up so where should i point the z6 distro on the a6 head?
GreenEHDriver
Aug 17, 2006 10:40 AM
AgentJam
Nov 30, 2004 12:58 PM
