itr rear lower control arms question
Old Jul 18, 2004 | 02:32 PM
heygotboost's Avatar
Default itr rear lower control arms question
I just got a set of itr lower control arms from japan. The only thing is that the guy sent two right itr lower control arms and i contacted him and he says it doesn't matter what side the lower control arms are from they fit the same. Does anyone know anything about this?
Old Jul 18, 2004 | 02:34 PM
donz's Avatar
Default Re: itr rear lower control arms question (94eg9)
I think he is right, If I remember correctally, I seem to recall that they are both the same part.
Old Jul 18, 2004 | 02:39 PM
esponet's Avatar
sway bar bolts. you will have to rig something up if you flip the right side to use on the left.
(drill if it does not have a hole, then use a nut for the bolts)
Old Jul 18, 2004 | 02:40 PM
MugenEg6's Avatar
Default Re: itr rear lower control arms question (donz)
No i believe the part numbers are different and the sway bar mount will be on the wrong side of the arm i believe
Old Jul 28, 2004 | 05:06 PM
B18Tahtaras's Avatar
Yeah, i checked the ITR in my shop, and there would be a bit of a problem with the sway bar bolts.
Old Jul 28, 2004 | 07:18 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: itr rear lower control arms question (MugenEg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenEg6 &raquo;</TD></TR><TR><TD CLASS="quote">No i believe the part numbers are different and the sway bar mount will be on the wrong side of the arm i believe</TD></TR></TABLE>
Yup. The rear LCA's are marked (L or R) and the part#'s are different.
dc2leftovers
Jul 24, 2009 12:27 PM
baboonstyle
Suspension & Brakes
Nov 12, 2007 05:02 PM
louie3252
May 15, 2006 10:01 AM
DerangedEG
May 14, 2004 11:48 AM
agent marlon
Nov 11, 2002 04:41 PM
