boost--good or bad idea?
Old Jul 17, 2004 | 08:53 PM
goldenboi's Avatar
Default boost--good or bad idea?
would it be a horrible thing to boost a typer motor or just pointless?
Old Jul 17, 2004 | 08:58 PM
Smeeg Heed's Avatar
Default Re: boost--good or bad idea? (goldenboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldenboi &raquo;</TD></TR><TR><TD CLASS="quote">would it be a horrible thing to boost a typer motor or just pointless?</TD></TR></TABLE>
Some purists might say no. If you have a B18C5 then it's built for NA power. It's your motor though and a lot of R owners boost and love it.
You could always sell the B18C5 and drop a B18C1 (GSR motor) in it + have money left over. Boost that and it will be virtually as good as the R motor.
Like I said though, a lot of turbo R owners around. They will probably have better input than I.
Edit: forgot to mention that the B18C1 is also slightly lower compression so it would be able to handle a little more boost.
Old Jul 17, 2004 | 09:43 PM
98itr0448's Avatar
Well, you could spend 1500-2000 on internals and gain 20hp or spend the same money and get a used jrsc and get 40-50. Of cours if you have the money, turbo is the way to go to make lots of power. I personally would rather have the jrsc because the itr is my daily driver and I feel it would be a better set up than turbo for my needs. You have to remember that the R is a great n/a motor, not the greatest w/ forced induction. However, that doesn't mean you shouldn't do it, as there are many happy owner's of boosted R's. If you want to make big hp then go turbo, if your like me and want 50% more torque at rediculusly low rpm's then go jackson. Whatever you do, enjoy!
Old Jul 17, 2004 | 09:44 PM
Mythias's Avatar
Default Re: boost--good or bad idea? (98Itr-0448)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98Itr-0448 &raquo;</TD></TR><TR><TD CLASS="quote">Well, you could spend 1500-2000 on internals and gain 20hp or spend the same money and get a used jrsc and get 40-50. Of cours if you have the money, turbo is the way to go to make lots of power. I personally would rather have the jrsc because the itr is my daily driver and I feel it would be a better set up than turbo for my needs. You have to remember that the R is a great n/a motor, not the greatest w/ forced induction. However, that doesn't mean you shouldn't do it, as there are many happy owner's of boosted R's. If you want to make big hp then go turbo, if your like me and want 50% more torque at rediculusly low rpm's then go jackson. Whatever you do, enjoy!</TD></TR></TABLE>
you get one big from me.
Old Jul 19, 2004 | 02:12 PM
goldenboi's Avatar
Default Re: boost--good or bad idea? (mythias)
I want i to be reliable and dont want to blow the **** up. then again I dont necessarily need to compete w/ ferraris or anything just want to hang with gts and camaros. ok I want to spank some asses
Old Jul 19, 2004 | 03:27 PM
PIMPAZZITR's Avatar
run a basic turbo kit with head gaskets and studs, use an VAFC to drop the vtec cross over slightly. 9psi with a slightly rich tune should haul ***...
Old Jul 19, 2004 | 03:37 PM
Finland's Avatar
you can almost double your ITRs power by turboing it, with a good tune.
Just keep it under 10Psig.
Been there done that...
Old Jul 19, 2004 | 04:00 PM
Dr Pooface's Avatar
Default Re: (boost psycho)
Reliable + turbo = Lots and lots of $$$. Think about it before you jump in.
milanoteggy
Jul 26, 2012 11:54 AM
em1gangsta
15
Feb 3, 2008 11:26 AM
MugenHonda
Apr 25, 2007 10:49 AM
HYREV2NR
Jan 22, 2006 06:58 PM
