Converting a 1.3 litre Carby to a 1.6 or 1.8 VTEC EG3
Old Jul 17, 2004 | 08:02 PM
Farkis's Avatar
Default PLEASE HELP - Converting a 1.3 litre Carby to a 1.6 or 1.8 VTEC EG3
I live in Australia and i have just bought a eg3 1.3litre Carby and i want to build this into a show car. is it possible to convert a Carby innto a fuel injected VTEC or swap engines to a 1.6 or 1.8 VTEC so i can turbo the car THanx please help im new on the scene of civics
If i were to do a engine swap with a 1.8 VTEC or EFI what other parts must i change?
Modified by Farkis at 9:26 PM 7/17/2004
Old Jul 17, 2004 | 08:06 PM
CivicVX94's Avatar
Default Re: Converting a 1.3 litre Carby to a 1.6 or 1.8 VTEC EG3 (Farkis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Farkis &raquo;</TD></TR><TR><TD CLASS="quote">I live in Australia and i have just bought a eg3 1.3litre Carby and i want to build this into a show car. is it possible to convert a Carby innto a fuel injected VTEC or swap engines to a 1.6 or 1.8 VTEC so i can turbo the car THanx please help im new on the scene of civics </TD></TR></TABLE>
It is definatly possible to convert a carbed engine to fuel injected, I believe Summit Racing sells the conversion kits. And as far as converting to Vtec, look up the thread by Bauley Civic about Mini-Me swaps, it will explain EVERYTHING. However i dont know if it's ever been done with a 1.3L. Also it is possible to swap the engine out fairly easily. Goodluck.
Old Jul 17, 2004 | 08:16 PM
K I T T's Avatar
Default Re: PLEASE HELP - Converting a 1.3 litre Carby to a 1.6 or 1.8 VTEC EG3 (Farkis)
Yes it is very possible. Although it is more expensive coz you hav to reharness the entire car since EFI and carb harness is very different. You will have to replace the fuel tank too and install an electric fuel pump.
If Im not mistaken, that 1.3 carb motor is a "d-series" although it says different on the block. You can do a minime or do a full swap, its up to you.
92 - 95 civic hatchback here in the philippines all came with a 1.2L carb. Although called a"PH12" it is also a "d-series" and will bolt on any "d" parts like the head.
And we also do swap, minime or convertion to EFi with Vtec.
d!ckface
22
May 14, 2006 10:41 AM
baddog
Sep 17, 2004 04:12 PM
integracivic94
Oct 26, 2003 01:22 PM
