1.6 Vtec or Non Vtec???
Old 05-11-2006, 05:28 PM
d!ckface's Avatar
Default 1.6 Vtec or Non Vtec???
i was wondering if there is a noticible difference between a vtec and a non vtec 1.6 sohc. Any suggestions?????
Old 05-11-2006, 05:41 PM
Jedi_Sol's Avatar
Default Re: 1.6 Vtec or Non Vtec??? (GSRh@tch)
What kind of differences are you looking for?
For starters, 1.6liter VTEC engines have VTEC, duh.
1.6L VTEC = 127ish hp.
1.6L Non-VTEC = 100ish hp (depending on the model)
Old 05-11-2006, 06:13 PM
d!ckface's Avatar
Default Re: 1.6 Vtec or Non Vtec??? (Jedi_Sol)
like is there a difference in performance? is there a change in sound when vtec hits, like a bseries does, or is it more subtle...
Old 05-11-2006, 06:17 PM
Jedi_Sol's Avatar
It's a sublte change with the SOHC VTEC. If anything, you can just barely hear the engine change tones when it hits.
But the other thing that makes VTEC engines faster is the shorter transmission too. NON-VTEC motors have longer gears, better for fuel economy.
Old 05-11-2006, 06:26 PM
d!ckface's Avatar
ok, thanks for the help
Old 05-11-2006, 06:27 PM
d!ckface's Avatar
is 150 good for a full 1.6 vtec swap?
Old 05-11-2006, 06:29 PM
11SEC CIV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch &raquo;</TD></TR><TR><TD CLASS="quote">is 150 good for a full 1.6 vtec swap?</TD></TR></TABLE>
yes
Old 05-11-2006, 06:32 PM
Jedi_Sol's Avatar
Default Re: 1.6 Vtec or Non Vtec??? (12SEC CIV)
That's a steal.
Old 05-11-2006, 06:34 PM
d!ckface's Avatar
awesome. im puttin it in my ek this weekend and i was wondering what i have to do for the vtec. just use the engine harness and the ecu??
Old 05-11-2006, 07:00 PM
B18C EG2's Avatar
Location: Home Of The Players And PIMPS, IN, united states
if its a d16y8 swap then yes...drop it in and go..
if its a d16z6 swap then you need a few things...
that big red thing up at the top named search will help you out with that tho...
Old 05-11-2006, 07:02 PM
d!ckface's Avatar
Default Re: 1.6 Vtec or Non Vtec??? (Stupid EK)
The car is a y8 vtec, ohhh schnapp gonna have it in this weekend, as long as the rain holds out
Old 05-11-2006, 11:14 PM
all_conference's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jedi_Sol &raquo;</TD></TR><TR><TD CLASS="quote">It's a sublte change with the SOHC VTEC. If anything, you can just barely hear the engine change tones when it hits.
But the other thing that makes VTEC engines faster is the shorter transmission too. NON-VTEC motors have longer gears, better for fuel economy.</TD></TR></TABLE>
How do you explain d15z1 vtec-e and its long gears?
Old 05-12-2006, 12:11 AM
Smash03's Avatar
Default Re: 1.6 Vtec or Non Vtec??? (all_conference)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_conference &raquo;</TD></TR><TR><TD CLASS="quote">How do you explain d15z1 vtec-e and its long gears?</TD></TR></TABLE>
Well, because the vtec-e is an economy car. It should have longer gears to save more gas. If you have short gears with vtec-e, then what's the point? Hope that clears things up.
Old 05-12-2006, 12:23 AM
Jedi_Sol's Avatar
Default Re: 1.6 Vtec or Non Vtec??? (Smash03)
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.750 for Si HB and Del sol Si
or------0.702 for 2 dr or 4 dr sedan
Final Drive---4.250
CX /VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
The higher the number, the shorter the gear = quicker acceleration
But I think I understand where you get confused when I say "cars with VTEC." In a nutshell, people on HT have a mutual agreement that when someone says "VTEC" they are talking about the high-cam-profile-mad-power engines.
Yes, VTEC-E is technically a VTEC engine, but it achieves its variable valve timing and lift fuciton through the electronic manipulation of the valves. Low rpms = 2valves per cylinder. High rmps = 4 valves per cylinder. This generally does not give you the mad power needed to achieve this result:
Old 05-12-2006, 01:13 AM
LuCkYcOuPe's Avatar
1.6 non vtec is from 96+ dx model civics also, the ones with beehive style cats on the exhaust manifold. oh ya throw a header on that y8
Old 05-12-2006, 02:21 AM
SuperSi's Avatar
Default Re: 1.6 Vtec or Non Vtec??? (CRF1600ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRF1600ej1 &raquo;</TD></TR><TR><TD CLASS="quote">1.6 non vtec is from 96+ dx model civics also, the ones with beehive style cats on the exhaust manifold. oh ya throw a header on that y8 </TD></TR></TABLE>
forget the head slap a turbo on that motor . You got a good deal
Old 05-12-2006, 03:40 AM
crashoveride's Avatar
Does a 97 del sol s w/ the d16y7 have a better gear ratio then a civic w/ same motor? I have the sol and ratio feels quik, redline 2nd @ 60 mph
I bought a clutch for it and tried using one from a 96- civic dx and it didnt fit. The sol had a different flywheel.
Is it possible that the sol has a y8 tranny on a y7 motor from factory?
Old 05-12-2006, 09:22 AM
Jedi_Sol's Avatar
Default Re: (crashoveride)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashoveride &raquo;</TD></TR><TR><TD CLASS="quote">
Is it possible that the sol has a y8 tranny on a y7 motor from factory?</TD></TR></TABLE>
Yes, d-series engine/trannys are interchangeable
Old 05-12-2006, 10:47 AM
E46Kid's Avatar
Sohc Vtec!
Old 05-14-2006, 06:53 AM
d!ckface's Avatar
Default Re: (EkSi)
im told it has a delsol trans on it but i cant tell... is it better or worse??
Old 05-14-2006, 09:23 AM
Jedi_Sol's Avatar
Default Re: (GSRh@tch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch &raquo;</TD></TR><TR><TD CLASS="quote">im told it has a delsol trans on it but i cant tell... is it better or worse??</TD></TR></TABLE>
It's a little worst because the shifting fork is made of aluminum, so they are prone to breaking.
The y8 shifter forks are made of steel, more durable.
Old 05-14-2006, 09:54 AM
plz turn off trial user's Avatar
Default Re: (Jedi_Sol)
nah its better the y8 shifter forks are prone to bending because the stell is a little thinner
Old 05-14-2006, 10:41 AM
noboostedEGo's Avatar
It depends on what del sol tranny it is. If it's a 96+ si transmission, it's the same thing. If it's pre96, it has a z6 tranny, which is pretty much the same but they have an aluminum shift fork versus the steel y8 shift fork.
zzzhondazzz
04-01-2006 10:40 AM
escape2me
12-25-2004 11:51 PM
xvracing
05-01-2004 01:49 PM
escape2me
04-26-2004 02:44 PM
civickid03
03-25-2004 11:00 AM
Quick Reply: 1.6 Vtec or Non Vtec???
