power windows in a cx?
Old Nov 24, 2001 | 01:29 AM
jdmrealm's Avatar
New User
Default power windows in a cx?
Hi,
How can I put power windows in a cx? Does the Si come with power windows? if so..can I get si doors?
Thanks,
Ray
Old Nov 24, 2001 | 01:40 AM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: power windows in a cx? (4g63turbo)
This is my aftermarket power window kit. Costed $130, 3 hours to install.
[Modified by GapxGuy, 11:11 PM 11/26/2001]
Old Nov 24, 2001 | 01:51 AM
mr2's Avatar
mr2
Default Re: power windows in a cx? (GapxGuy)
nice custom switches I like!
Old Nov 24, 2001 | 03:22 AM
jdmrealm's Avatar
New User
Where can I get that kit from and what is it called?
Old Nov 24, 2001 | 03:27 AM
GapxGuy's Avatar
It's a spal power window kit, you can get it off ebay or any site that sells it. Rolls your window up/down faster than stock. Those are BMW style switches, not included with the kit.
Old Nov 24, 2001 | 03:32 AM
jdmrealm's Avatar
New User
Thanks
One more thing you may be able to help with..My car has a gsr dash..but the ac/heater controls arent hooked up and I cant find the wiring for it..Do I have a heater box? Where is the wiring that I cannot find?
Thanks,
Ray
Old Nov 25, 2001 | 11:01 PM
beeboyee's Avatar
Default Re: power windows in a cx? (MiGs)
i could have swarn those buttons came off a BMW
Old Nov 26, 2001 | 12:16 AM
SjCiViCHB's Avatar
Did you do the install yourself? if so was it easy to wire and stuff? i want powerwinddows and doorlocks, im tired of reaching across the car , manually rolling down the window to holla at the girl on my rightside. also how much did the kit cost you?
Old Nov 26, 2001 | 01:13 AM
is3oo's Avatar
Can you use the spal window kit and connect it with a 99-00 Si/EX door panel with the stock power window switch?
[Modified by KPxRyDa, 2:13 AM 11/26/2001]
Old Nov 26, 2001 | 10:14 AM
HOND PWR's Avatar
I just finished putting power windows and power locks in My 93 Civic cx today. Its pretty easy if you have all the parts. I used 92-95 civic ex parts from the junkyard everything just bolts and plugs in.
Old Nov 26, 2001 | 11:04 AM
sloppy_seconds's Avatar
Banned
Default Re: power windows in a cx? (HOND PWR)
i was thinking of doing this but doing it the more expensive way and using either Si or EX doors, the only question i would have would be wiring the friggin' things!
--justin
Old Nov 26, 2001 | 11:45 AM
Unjockable's Avatar
New User
Are those SI seats I see?
Old Nov 26, 2001 | 02:11 PM
GapxGuy's Avatar
Default Re: power windows in a cx? (stinkysnowman)
Yes, those are Si seats.
Yes, you can use ex, si door panels and use the switches.
Yes, I installed them myself...took 3 hours.
No, it wasn't hard, pretty easy actually.
Old Nov 27, 2001 | 11:13 AM
Banned
talk about punctual, you answered all the questions in one short breath!
--justin
Old Nov 27, 2001 | 02:17 PM
SjCiViCHB's Avatar
everything bolts right in? really? what about the wiring? was that easy or is it pretty hard? thats the only thing that im scared of, the wiring.
Old Nov 27, 2001 | 07:56 PM
jdmrealm's Avatar
New User
I have those power door lock modules, but only the unit with the motor inside it ( that black thing ) i dont have the brackets or anything..where can I get it from?
Old Nov 27, 2001 | 08:03 PM
GapxGuy's Avatar
I'm sure you can customize your own piece, it's just a metal rod.
Old Nov 28, 2001 | 09:55 AM
SIINSI's Avatar
I have some of the actual factory pieces if anyone needs em. I have what is called the "Floor Harness" which is the main harness needed that goes t the doors, fusebox, etc. I also have the regulators for 96-00 Civic and the windows too
Miguel
nycmad@si.rr.com
civicsir94
Jun 25, 2008 09:13 PM
97 CIVIC EX
Mar 26, 2003 11:45 AM
jcivic
Mar 1, 2003 10:57 AM
JDMCRX
May 27, 2002 02:22 PM
