safe to use ctr/jun type 2 cams on stock b16?
Old Jul 17, 2004 | 01:51 PM
jbell's Avatar
Default safe to use ctr/jun type 2 cams on stock b16?
is it safe to drop these in on a b16 that is pretty much stock, except for normal bolt ons, intake/header/exhaust, cam gears... you know... basically can the stock valve train handle it?
i assume same answer for itr cams?
Old Jul 17, 2004 | 07:07 PM
jbell's Avatar
Default Re: safe to use ctr/jun type 2 cams on stock b16? (jbell)
anyone?
Old Jul 18, 2004 | 03:48 PM
SiRP's Avatar
Read somewhere that it's best if you make it twin springs for the exhaust valves as well (only the intake valves have twin springs on the stock b16). But i also read somewhere else that you should have no problems with the stock valve train IF you have no intention of upping your rev limit.
I have CTR cams on mine. They're pretty much bolt-on. Didn't change the springs.
No problems so far. It would be good to dyno tune after install.
Old Aug 1, 2004 | 09:50 AM
phatj0e209's Avatar
wasup dude i have some CTR cams im triyng to get rid of you looking for any cams?
mrx
Aug 23, 2006 04:44 PM
jdmjeff
14
Aug 2, 2006 03:35 PM
korsou
Oct 27, 2005 07:12 PM
caranjo
Feb 24, 2005 09:19 AM
ImportHatch
Jan 25, 2002 12:18 AM
