Do u need to up grade valve springs or retainers to run high compression pistons??
Old Nov 24, 2001 | 12:37 AM
Tyson Ballou's Avatar
Default Do u need to up grade valve springs or retainers to run high compression pistons??
say u have gsr block and you run ctr pistons which upst he ratio to like 12.5, do u need to upgrade the reainers or valve springs. Oryou can run it just with the pistons?
Old Nov 24, 2001 | 03:00 AM
C-speed's Avatar
Default Re: Do u need to up grade valve springs or retainers to run high compression pistons?? (Martin De Po
you only need to upgrade the valve train if you upgrade the cams.
Old Nov 24, 2001 | 04:43 PM
da6_b17a's Avatar
New User
no doubt.
Old Nov 25, 2001 | 07:50 PM
93LSivic's Avatar
Well what if you plan on just revving higher than the rev limiter. Or in my case if I have a chipped ecu w/o a limiter and dont wanna drop a valve from a mis-shift--especially when I finally get my snail on.
jdm.fanatic
Jun 18, 2014 09:28 AM
Ruben_EG
Aug 8, 2010 11:57 PM
TURBL0W
Nov 9, 2005 01:17 AM
EFin' Kyle
Sep 26, 2005 08:20 PM
racinategra
May 1, 2005 05:14 PM
