major problems!!!! please someone help
Old Jul 17, 2004 | 11:26 AM
bens_redeg's Avatar
Default major problems!!!! please someone help
ok here we go...... about a week ago my car wouldnt start. it turns over but doesnt start. so far i have checked and changed fuel pump, fuses, main relay, distributor cap, rotor, ignition control module, coil, plugs, plug wires. ive also checked my timing, starter and battery. so heres the thing...sometimes it starts and runs pretty good(usually if i dont start it for a while), sometimes it starts and runs like **** (really groggy) other times it doesnt start at all and my main relay just keeps clicking when i turn the key to start. sometimes i can here my fuel pump engage and sometimes it doesnt. i have only two options left before i take it to a mechanic: 1)change the ecu 2)i change the whole distributor unless someone might know what this is
the only thing i can tell you is before it wouldnt start i pulled my cluster out to change a bulb in it.
any ideas or comments. whatever you can do to help would be greatly aprreciated thanks alot
Old Jul 18, 2004 | 08:23 AM
bens_redeg's Avatar
Default Re: major problems!!!! please someone help (bens_redeg)
ttt
Old Jul 18, 2004 | 08:24 AM
Deemeetree's Avatar
Electrician
Alternator?
Old Jul 18, 2004 | 10:06 AM
bens_redeg's Avatar
Default Re: (Dimi)
no checked it its only about 4 months old but thanks any other thoughts
Old Jul 18, 2004 | 12:08 PM
EK45VTi's Avatar
Default Re: (bens_redeg)
Key cylinder?
Fuel filter???!?!?!?!?!?!? very very common problem if not changed
Air filter???
Injectors???
Unknown devices or dust or whatever in the intake system???
I'm out!!!
Old Jul 19, 2004 | 03:48 PM
bens_redeg's Avatar
Default Re: (KKVTi)
bumpity thanks for the replys im gonna change my fuel filter and ill post if it works
Old Jul 21, 2004 | 03:41 AM
bens_redeg's Avatar
well i changed out my fuel filter and it starts everytime now but it still runs really shitty like its idling really low like 400 and when i press on the gas its slow for the rpm to get up there im thinking either ecu or injectors
Old Jul 21, 2004 | 05:01 AM
EK45VTi's Avatar
Air filter???
Bad fuel???
O2 sensor???
Old Jul 21, 2004 | 06:00 AM
-Trinitron-'s Avatar
Default Re: (KKVTi)
Clean your O2 sensor(s) with carb cleaner. Reset the ecu. Have you pulled any codes? You may also have a bad cell in the battery. Causing it to only not start once in a while.
Old Jul 21, 2004 | 01:22 PM
bens_redeg's Avatar
Default Re: (-TRINiTRON-)
well when i changed the fuel filter it backfired a few times. any clues??
Old Jul 21, 2004 | 04:38 PM
bens_redeg's Avatar
ok im throwing code 3 which is my map sensor which would explain my symptoms so does anyone know how to change it out or what i should do thanks to all
Old Jul 21, 2004 | 04:42 PM
vansprinkle's Avatar
yeah, it is 2 screws and should be on or by your throttle body. they are expensive so I would first find a friend with a similar civic and borrow his to make sure that is what it is.
Old Jul 23, 2004 | 03:35 AM
bens_redeg's Avatar
Default Re: (vansprinkle)
ok i borrowed a buddys map sensor put it in and now im throwing a code 7 which is my TPS so im gonna change that out today
Old Jul 29, 2004 | 08:43 PM
bens_redeg's Avatar
ok it was my o2 sensor. it had a little too much slack in the harness and it was rubbing up against my drive axle and getting hot and shorting out all that work for nothing
90_Si
31
Oct 5, 2019 07:42 AM
88LsRex
May 29, 2012 03:41 PM
sick_eg6
Jan 14, 2008 05:20 PM
Xumarius
Nov 1, 2004 08:07 AM
TheOne
Apr 9, 2003 06:15 AM
