V-TEC
DAMN, I was driving on da freeway and took the RPm paseed 5200, but it didnt seem like that the V-TEC kicked in, I have a JDM B16A1 what could be the problem? If anyone knows why please help me, Oh yah I didn do a search before I posted this and I couldn't find any simillar topic
Yea my car does rev up to 8000rmp. The Ecu does give a code 1 long blink and seven short once, indicating the Speed Sensor, and I do let my car warm up before I drive it. It seems like the car is struggling a lil bit for speed and bogs a lil to. Then it picks up speed and starts to do the same thing again. Any I deas ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteCRXSi »</TD></TR><TR><TD CLASS="quote">EL, its V-TEC, like I said before the speed sensor is a lil bit loose I guess it comes out when I drive the car, I gotta figure out a way to fix that</TD></TR></TABLE>
LOL!!!
Do me a favor, go outside and take a pic of your stock valve cover and then post it on here.
LOL!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteCRXSi »</TD></TR><TR><TD CLASS="quote">Hamilton thanx for the pics, El there you go those are the pics.
Again, notice how it says VTEC and not V-TEC???
USE IT OR DIE
Teh Coolest site ev4r
https://honda-tech.com/zerothread?id=917561
https://honda-tech.com/zerothread?id=921472
Edit: You have been here 282 days and you STILL haven't found common sense OR the search function....
check your oil. and what kind of oil are you using? if your oil is low it wont work. i tried some mobil non synthetic oil, and mine ran like ****. then i changed it to synthetic oil and HOLLY **** SHES ALIVE. try that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHatch101 »</TD></TR><TR><TD CLASS="quote">check your oil. and what kind of oil are you using? if your oil is low it wont work. i tried some mobil non synthetic oil, and mine ran like ****. then i changed it to synthetic oil and HOLLY **** SHES ALIVE. try that
Damn dooode!??!?!?
Did you have gear oil in there before the synthetic?
</TD></TR></TABLE>Damn dooode!??!?!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">
Damn dooode!??!?!?
Did you have gear oil in there before the synthetic?</TD></TR></TABLE>
must have been like some 20W stuff.
Changing oil types does NOT make any noticable preformance gains
Damn dooode!??!?!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Again, notice how it says VTEC and not V-TEC???</TD></TR></TABLE>
own3d
own3d
yeah i cant tell how fast im goin either, and my vtec doesnt engage either. just did the swap bout a week ago and my friend tried to combine my hf plug wit the b16 and my speedometer dont work. but hey i used to drive a hyundi wagon wit NO TACH in the cluster and the speedometer didnt work either HAHAHA...
without the VSS there is no signal from the tranny, So the ecu has no idea what is going on. So its not going to run right. Just go to a junkyard and pick up a speedometer cable
The JDM motor probally came with a electronic VSS. no problem, for a quick fix unbolt the top of the vss, (the plug) 2 10mm bolts. and stick the vss cord down into the VSS it should fit right in there.
