Axles?
Old Jul 17, 2004 | 07:34 AM
Tommy_Gunns's Avatar
Default Axles?
The picture is courtesy of MwGSR:
What is that rubber ring around the middle of the shaft? Can it be removed if it serves no purpose for ITR?
The top shaft in the picture, the ABS ring is the one between the CV boot retaining ring and the shaft spline (top right joint), right?
Thanks.
Old Jul 17, 2004 | 07:37 AM
Comp97GSR's Avatar
Default Re: Axles? (Tommy_Gunns)
It is a dampener. Takes the vibration out of the axles... probably b/c they are not balanced.
Yes that is the ABS ring.
Old Jul 17, 2004 | 07:38 AM
mtber's Avatar
Ring in the middle of the shaft = balancer gimmic, comes on oem axles only
The abs ring is the gold notched plastic ring on the spindle ends of the axles....
Old Jul 17, 2004 | 09:42 AM
Ill's Avatar
Ill
Default Re: Axles? (mtber)
Ummm. My 98 ITR does not have the balancer/damper rubber things. Looks like factory axles to me. What gives?
Old Jul 17, 2004 | 09:58 AM
Comp97GSR's Avatar
Default Re: Axles? (Ill)
Those are not ITR axles.
Old Jul 22, 2004 | 10:37 PM
Slow_Em1's Avatar
Default Re: Axles? (Comp97GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">It is a dampener. Takes the vibration out of the axles... probably b/c they are not balanced.
Yes that is the ABS ring.</TD></TR></TABLE> i always thought it was so the axle wouldnt hit the LCA, and if it did, it had that rubber to protect it
Old Jul 23, 2004 | 04:46 AM
owen_the_soyboy's Avatar
I've heard the LS axles do not have the dampener but GSR's do.
I dont know about ITR axles though....
Old Jul 23, 2004 | 05:47 AM
Erik95LS's Avatar
Default Re: Axles? (owen_the_soyboy)
my LS axles had dampers
Old Jul 25, 2004 | 11:26 PM
Slow_Em1's Avatar
Default Re: Axles? (Erik95LS)
what does it damper?
Old Jul 27, 2004 | 08:11 PM
Ill's Avatar
Ill
So, whassup? ITR's do or don't have rubber axle dampers? TIA
NsX_CrX
Feb 5, 2007 07:50 AM
JustinG60
Jan 1, 2007 12:20 PM
shuttle xer
Dec 31, 2005 01:56 AM
b18c inside
May 4, 2005 06:38 AM
nautica_t
20
Dec 17, 2004 10:48 AM
