sanding bondo/contourls of rear quarters.
Old Jul 17, 2004 | 07:17 AM
HamiltonRex's Avatar
Default sanding bondo/contourls of rear quarters.
Im having so much trouble sanding the filler. I just cant get it smooth. I mean it looks smooth but when you feel it, its wavy in some spots. Then when i sand down that spot the wave is gone but theres a new one right beside it. I started out with a bucket of filler. Now its half empty and there is almost none on the car.
Im using a orbital sander with 100 then 220 grit. And i have a coark block im using to sand by hand after and i just cant get it smooth!!. Should i get one of thoese sanders that are like a double palm sander size? There all flat, would that help at all?
How would you best describe the contour of the rear 1/4. From as far as i can tell it comes down, goes in a bit, then back out. And this contour fades off towards the back. Im just trying to match factory here.
Thanks!
Old Jul 17, 2004 | 07:22 AM
CRXBart's Avatar
Default Re: sanding bondo/contourls of rear quarters. (HamiltonRex)
I've watched my body man do several honda quarter's and he usually uses a flat block and hand sands the contour. I think that your orbital is just a little bit much for the job. Nothing like some good elbow grease.
Old Jul 17, 2004 | 08:42 AM
Default Re: sanding bondo/contourls of rear quarters. (CRXBart)
I tried again. I mixed up a bunch of bondo, put it on and did exactly what you said. As soon as i had a rough finish. I used a block and hand sanded it. Its nice and smooth. And for the contours at where the top of the bumper meets the body i used a impact socket as a sanding guide because it was rounded.
One trick i learned. If you have a small pit or something, dont try to sand it out because you will make a wave around it. Just mix up some bondo and just fill that small little pit.
Now ive got the passenger side perfect. I just have to finish off the drivers. Hopefully tommorow night we can spray a coat of primer.
The orbital works well for sanding the actuall car ive found.
Thanks! AnY other comments apreshiated
Scott Chapman
Paint and Body
10
Feb 8, 2023 07:53 PM
Vagitarian
Paint and Body
May 25, 2012 02:29 AM
gfex81
Apr 20, 2008 01:17 PM
msinsky14
Paint and Body
14
Aug 7, 2007 03:40 PM
H22a T13
Feb 27, 2006 09:16 PM
