Breaking in new cams
Hi
I did a search, but it offered more questions than answers.
I have just installed some Toda C cams and want to know how to break them in?
I know normal cams are run in at about 2000rpm for about 20 minutes, but I can't find any information on the Toda cams.
Thanks
Thanks
not really a break in required...cams are cams...just make sure you set the valve lash correctly and don;t leave it loose...can snap your timing belt or damage your tensioner pulley.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accorse07 »</TD></TR><TR><TD CLASS="quote">not really a break in required...cams are cams...just make sure you set the valve lash correctly and don;t leave it loose...can snap your timing belt or damage your tensioner pulley.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">With the Toda C's, I would keep it revved for the first 500 miles just to be on the safe side. Don't let it idle any longer than necessary.</TD></TR></TABLE>
listen to this one
listen to this one
