Tranny whine came out of nowhere
Old Jul 16, 2004 | 10:20 PM
Dyzee's Avatar
Default Tranny whine came out of nowhere
I did search but noone had the exact answer from my quick skimming.
I was driving towards downtown today in 3rd and out of nowhere a whine started. I completey freaked out because I thought I finally had my car running with no problems.
Symptoms:
Whine increases in speed/sound as Rev's climb
There is no whine when not in gear
Only whines when there is load on the tranny
no whine when revving car in neutral.
Now, I know im a BIT low on oil (maybe 1.7L instead of 2.0L) in my D16Z6 TRanny and I'll be doing a complete flush/replace fluid on it to see if it'll get rid of my whine.
Does anyone know what it could be?/
Old Jul 16, 2004 | 10:53 PM
murtnabila's Avatar
Default Re: Tranny whine came out of nowhere (Dyzee)
main bearing!
Old Jul 16, 2004 | 11:39 PM
bdotdan's Avatar
is it making noises when you depress the clutch or not? def a bearing but not sure which one.
Old Jul 17, 2004 | 04:50 AM
Dyzee's Avatar
When the clutch is pressed in the tranny makes no noise.
When the clutch is not pressed, tranny makes no noise ONLY in neutral.
When the cluch is not pressed and in gear, tranny makes whining.
Is it safe to drive my car with this whine? Will it damage my transmission?
Old Jul 17, 2004 | 06:51 AM
2lua's Avatar
Default Re: (Dyzee)
the input shaft bearing.
Old Jul 17, 2004 | 07:02 AM
SkRiBLaH's Avatar
Default Re: (2lua)
my guess is a chipped gear.
miss any shifts latly?
Old Jul 17, 2004 | 08:35 AM
cxSHOE's Avatar
i had this same problem in 1st and 2nd gears very faint whine, no loss of power either.
this problem came about then i changed all my bearings from the transmission.had enough oil. it was disassembled about 7 times, trying different things to find out what the hell the whine was. no jarred gears, or teeth and everything lined up great.
it came down to a shim replacement, on the differential which youhave to measure correctly. the helms manual goes through how to measure which size shim to get.
you can drive around with it but if the noise gets louder you will have to make some changes but if the sound stays the same just live with it and put some money away later on.
Old Jul 17, 2004 | 10:45 AM
accorse07's Avatar
im thinking you got a clutch problem and not a tranny problem.
Old Jul 17, 2004 | 11:01 AM
cxSHOE's Avatar
Default Re: Tranny whine came out of nowhere (accorse07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accorse07 &raquo;</TD></TR><TR><TD CLASS="quote">im thinking you got a clutch problem and not a tranny problem.</TD></TR></TABLE>its not a clutch probelm. clutches either dont grap which means your slipping, or you cant shift into gear. dont confuse hime with wrong information. besides clutches never whine.
Old Jul 17, 2004 | 11:10 AM
G U E C O's Avatar
mine made the same noise. and it was the main bearing. just my .02 cents
Old Jul 17, 2004 | 11:19 AM
Deemeetree's Avatar
Electrician
https://honda-tech.com/zerothread?id=596878
https://honda-tech.com/zerothread?id=912219
Old Jul 17, 2004 | 04:45 PM
Dyzee's Avatar
Ok well the noise has gotten significantly quieter. I can barely hear it in 1st and 2nd anymore and 3rd gear noise is pretty much gone.
Im going to replace my tranny fluid tommorow as it needs it(I know it for a fact).
Is it safe to still beat on it?
Edit: Also, the whine does get louder as I climb revs, but tends to dissapear at what sounds like 3800-4200RPM....any ideas?
E9CiViC1F
Aug 25, 2009 02:55 PM
ILS_09
Jan 26, 2009 04:59 PM
JDM3STAGEVTEC
Dec 23, 2008 12:10 PM
LostSolVTEC
Mar 8, 2004 10:23 AM
ILOVEGIRLS
Feb 25, 2002 04:10 PM
