Speedometer problem
Car: 91 Accord Wagon
I have a speedometer thats just plainly not working. The blinking signal says the same. The speedometer sometimes works and sometimes just flatlines at 0mph. Also sometimes the engine check light comes on randomly. Its really weird. Where should i start to check stuff?
check all your wiring connections....could be your speed sensor.
do this:
https://honda-tech.com/zerosearch type in speedometer and search under the archived content in the accord forum. there are several results, as i have just searched for it. read through those to see if you can fix your problem. the search link is your friend!
maybe if it was a different color it would make a difference
do this:
i have the same problem, boughten speed sensors yes two, wasn't the problem, i just purchased a new cluster.....waiting for it in the mail, hopefully thats the problem, i heard that speedometers can go bad, we'll i'll see.
psm321
Nov 27, 2018 03:13 PM
Accordloser
Jul 21, 2004 05:13 PM
olds_442
Jul 14, 2003 09:51 AM
