B16a Water pump 94 del sol vtec doesnt fit
Old Jul 16, 2004 | 11:50 AM
iavoidcontct's Avatar
Default B16a Water pump 94 del sol vtec doesnt fit
I just got a B16a from Hmotorsonline and im in the process of changing the timingbelt and i figured id change the waterpump also but the problem is the 94 del sol vtec doesnt fit the gear is smaller than the stock and the holes dont match up anyone ever heard of this? and is there anyway i can tell what year and car my enigne came out of? any help would be appreciated.
Old Jul 16, 2004 | 12:14 PM
AychTwenee2's Avatar
there are two different water pumps for the del sol. I had the same problem, but i had an ls pump and had the pulley switched from the ls to my stock b16. But, you need to take yours off and take it to whatever auto store you use and tell them that it's the other water pump. There are TWO different ones.
Old Jul 16, 2004 | 12:16 PM
oh yeah, look on the head under the number 4 cylinder and there will be a circle that has two numbers with a slash between them. like 8/9 or 9/0 . That is the year of the motor. 1989 or 1990
Old Jul 16, 2004 | 01:52 PM
crx_88_si's Avatar
Default Re: (VeeTekCrx)
try a 92-93 gsr water pump.
Old Jul 16, 2004 | 02:10 PM
smart monkey's Avatar
Default Re: B16a Water pump 94 del sol vtec doesnt fit (iavoidcontct)
get a 94-gsr pump. that is the same as the old B16a ones. the pulley size is the issue you have I bet. you probably got a sohc vtec delsol wp.
Old Jul 17, 2004 | 03:13 PM
Hey thanks i think im gonna go with the 19t waterpump all the holes match up i just hope the smaller gear doesnt cause more pressure and make any of my hoses bust at least i should have better water flow.
Old Jul 20, 2004 | 03:07 PM
ICeDoUt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">try a 92-93 gsr water pump.</TD></TR></TABLE>
Def. do that, thats what fit mine, i gotta order everything from a b17 basically, and it fits like a glove
Old Jul 20, 2004 | 03:10 PM
Davanca's Avatar
Default Re: B16a Water pump 94 del sol vtec doesnt fit (ICeDoUt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt &raquo;</TD></TR><TR><TD CLASS="quote">
Def. do that, thats what fit mine, i gotta order everything from a b17 basically, and it fits like a glove</TD></TR></TABLE>
Same here i had the same prob. Turned out to be 92-93 GSR. JDM B16A uses everything from that year Integra.
Old Jul 20, 2004 | 04:04 PM
crx_88_si's Avatar
Default Re: B16a Water pump 94 del sol vtec doesnt fit (davanca24)
thats because a b17 is basically a stroked b16.
Old Jul 20, 2004 | 05:06 PM
ICeDoUt's Avatar
Default Re: B16a Water pump 94 del sol vtec doesnt fit (crx_88_si)
but its just weird that usdm b16 parts don't fit some jdm b16's, yet the b17 usdm parts fit the jdm b16.
Old Jul 20, 2004 | 05:15 PM
RexB16's Avatar
ya, what they said. 92-93 gsr. its expensive too.
Old Jul 21, 2004 | 09:00 AM
vitrox's Avatar
i had the same problem, the dealership here is lame and didn't even know what a b16a1 was.. so I had to find the pump myself.. It only took 4 parts stores to find one.. but I had to order it and pray that it was the right one, was about $130 I think.
edit, i bought one for a 99 civic si. They had two listed, and I already tried one, so the only other logical choice was......
Anthony Marino
Oct 28, 2016 12:17 PM
tc_gts
Jun 1, 2005 08:24 PM
redcrx1
Nov 28, 2003 01:27 PM
FOrSfEd
May 9, 2002 08:24 AM
iwhichisme
Jan 21, 2002 07:24 PM
