QUESTION: LS/Vtec what's a good shifting point? Redline?
Old Jul 16, 2004 | 06:43 AM
Addicted2Racing's Avatar
Default QUESTION: LS/Vtec what's a good shifting point? Redline?
I have a LS/Vtec swap in my car, what is a good redline and what's a good rpm to shift gears?
Setup:
LS/Vtec
Crower cams
Crower Cam Gears
Thanks
Old Jul 16, 2004 | 06:47 AM
LSTEG96's Avatar
Default Re: QUESTION: LS/Vtec what's a good shifting point? Redline? (Addicted2Racing)
stock valve springs and retainers? 7200!
Old Jul 16, 2004 | 06:49 AM
3.504's Avatar
Default Re: QUESTION: LS/Vtec what's a good shifting point? Redline? (LSTEG96)
stock bottom end.... 7200
Old Jul 16, 2004 | 06:56 AM
Default Re: QUESTION: LS/Vtec what's a good shifting point? Redline? (3.504)
Have anybody go any higher without any problems? Let's say 8000?
It's got Ported gasket Matched head. Chipped P28 ecu.
Old Jul 16, 2004 | 07:00 AM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Addicted2Racing &raquo;</TD></TR><TR><TD CLASS="quote">Have anybody go any higher without any problems? Let's say 8000?
It's got Ported gasket Matched head. Chipped P28 ecu.</TD></TR></TABLE>
i got a chipped p28 ecu from ih8ricerz, rev limit at 9200.... in first, if im realllllly going for it ill shift at about 8600, just to keep it deep into vtec, then into 3rd and into 4th i shift right around 8200. i have arp head studs, rod bolts, different pistons, valve springs, retainers,
Old Jul 16, 2004 | 07:07 AM
LSTEG96's Avatar
oh, and brand new rod bearings too!
Old Jul 16, 2004 | 07:09 AM
Cause the shop that did my installation said I can shift at 8500 with my stock retainers and stuffs. But if I shift at let's say 7200 then it's gonna drop to NONE Vtec zone and takes couple of secs to get back to Vtec.
Old Jul 16, 2004 | 08:05 AM
allmotorteg_96's Avatar
i took mine to 8200 with no problems
Old Jul 16, 2004 | 09:32 AM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Addicted2Racing &raquo;</TD></TR><TR><TD CLASS="quote">Cause the shop that did my installation said I can shift at 8500 with my stock retainers and stuffs. But if I shift at let's say 7200 then it's gonna drop to NONE Vtec zone and takes couple of secs to get back to Vtec. </TD></TR></TABLE>
couple secs? u must be slow.
Old Jul 17, 2004 | 08:27 PM
3.504's Avatar
i'd want to get that crank balanced a little w/ the rotating assembly, shot peen the rods and use arp rod bolts. a girdle and pcv breather aren't a bad idea either... thats a pretty cheap way to strengthen things up for 8000rpm
Old Jul 17, 2004 | 08:32 PM
kNOwLedGeDA9
Guest
Posts: n/a
I would say to shift at 7,800 RPM but you dont have stock B-series cams, which make max power at 7,800. Your stock block REALLY shouldn't go past 7100 but shifting there would be foolish.
Old Jul 19, 2004 | 10:27 AM
Circuit Star-29's Avatar
Default Re: (kNOwLedGeDA9)
Get your crank balanced and go to a dyno. You'll see where you should shift by looking at the power curve.
Old Jul 19, 2004 | 10:49 AM
hi mom's Avatar
Default Re: (nathan atwell)
My buddy has been building LS/VTEC's for years and years. He tuned mine with stock bottom end for 7600 redline with a 4800 vtec changeover. I am also running hondata p72.. buttttttttttttt if your runnning stock bottom, he told me no higher then 7600, 8000 is pushing it unless you have GSR OIL/WATER pumps.
Old Jul 19, 2004 | 11:31 AM
jdm_lover's Avatar
hahahaha
i 2nd that
8200 should be perfect...just dont bonce it!
Old Jul 19, 2004 | 12:54 PM
LSvtec03's Avatar
Default Re: QUESTION: LS/Vtec what's a good shifting point? Redline? (jdm_lover)
7500-8000
stock ls bottom, stock gsr top. absolutely no problems for over a year, about 15k miles
paton5g
Engine Management and Tuning
Oct 5, 2008 09:13 AM
N20Integra25
Jan 17, 2007 12:43 PM
1.8 tuner
May 25, 2006 04:52 PM
LL2009
Oct 5, 2005 11:24 AM
Homer_Simpson
Sep 29, 2001 05:01 AM
