Breaker Bar Size for 2001 Accord ATF Change?
Previous posts have mentioned using a breaker bar to remove the drain bolt.
What would be the recommended size to buy? All I have is a 3 /8" dr. Ratchet.
Also, would spraying the drain bolt with either WD40 or silicone spray help?
Thank you.
Thank you.
Thank you for the quick repy!
So 36 inch would be a good length, but I thought the recommended drive size was
3/8"?
Please forgive my ignorance...
3/8"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by under advisement »</TD></TR><TR><TD CLASS="quote">1/2 Inch drive 36 inch bar is a good investment.</TD></TR></TABLE>
The ATF bolts are usually really tight, I don't think the 3/8 allows for lots or torque. I just broke one over the weekend trying to get a medium size bolt out.
nighthawkgsr
Sep 20, 2007 06:52 AM
MulletManRockStar
Sep 3, 2004 10:46 PM
