Question about Torque Wrench
Old Jul 16, 2004 | 05:00 AM
.water's Avatar
Default Question about Torque Wrench
just got one...but when iam not using it has to be set on lowest point right? but handle still have pressure on it..do i have to set belowest torque setting so handle dont have any pressure on it..
Old Jul 16, 2004 | 05:03 AM
EE_Chris's Avatar
Default Re: Question about Torque Wrench (SpoonKillerB)
If its a click type, set the dial to the torque needed and tighten till you hear the click.
If its a beam type, the needle should be resting on 0 - tighten with a smooth pull till the needle is over the torque desired.
Old Jul 16, 2004 | 05:17 AM
.water's Avatar
Default Re: Question about Torque Wrench (EE_Chris)
thanks for the INFO..but that is not the answer iam looking for^^
Old Jul 16, 2004 | 06:28 AM
rapid_roy's Avatar
It doesn't have to be set to zero when not in use, but you should certainly set it low. I set mine to around 15lb/ft.
Old Jul 16, 2004 | 06:42 AM
EE_Chris's Avatar
Well, your Q is a little confusing - but it seems, after re-reading, that what you're asking is that when not in use, how should it be stored - to that I answer "with the dial set to the lowest point"
On my Craftsman, there is actually a little label, while twisting the bottom adjuster, that says "stop".
But you asked something about 'pressure on the handle' which sorta made it seem like you're trying to understand how to use it properly - my bad.
arren123
Jul 20, 2010 12:51 PM
IntegraTypeR
Jul 31, 2006 05:44 PM
99lude
Dec 3, 2003 12:53 PM
HX_Guy
Jan 12, 2002 10:58 AM
El Cucui
Jun 24, 2001 01:21 PM
