b18c into 92 civic cx
I've never done an engine swap before. Do the stock b18c motor mounts bolt right into my cx engine compartment? If i use my cx wiring harness what extra wires do i have to run? Any coments will be very helpful.
the teg mounts will bolt into the chassis fine. if you use a cx engine harness you need to wire in vtec,vtop,knock,IAB,and the three wires to make up the 4 wire O2. there are diagrams guys have posted online but I don't have any sorry.
id recommend clutchmaster or ACT clutches and flywheels. ive got a stage 3 CM clutch and lightened flywheel in my H22 CX hatch
most of the answers you need, you can find by using the Search option. you can find TONS of good info if you search Archived Content as opposed to Recent Topics. make sure you use words/phrases that have 3 or more letters. things like "cx" and "eg" wont work in search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbscivichb92 »</TD></TR><TR><TD CLASS="quote">I've never done an engine swap before. Do the stock b18c motor mounts bolt right into my cx engine compartment? If i use my cx wiring harness what extra wires do i have to run? Any coments will be very helpful.</TD></TR></TABLE>
this should help since you didn't bother using the SEARCH option: https://honda-tech.com/zerothread?id=650230
hatchness135
Aug 5, 2006 09:30 AM
