smoke from spark plugs
Old Jul 15, 2004 | 06:20 PM
boostedeghatch's Avatar
Default smoke from spark plugs
when i take my spark plugs out, you can see white smoke come up, what does that mean. the car revs up like **** also and doesn't run right. the plugs have oil on them also.
i'm thinking the rings are bad.
Old Jul 15, 2004 | 06:26 PM
Del Sizzle's Avatar
Default Re: smoke from spark plugs (boostedeghatch)
If I were you I'd check head gasket and valves.
Old Jul 15, 2004 | 06:29 PM
ABK's Avatar
ABK
Default Re: smoke from spark plugs (Del Sizzle)
sounds like a classic blown headgasket. Since there is white smoke pooring out that means you are burning coolant.
Old Jul 15, 2004 | 07:23 PM
a new headgasket was just put on.
Old Jul 15, 2004 | 07:24 PM
........'s Avatar
did you resurface the head?
Old Jul 15, 2004 | 07:30 PM
delScho's Avatar
Default Re: smoke from spark plugs (95lx4dr)
And use a new head gasket? Was the head torqued down properly?
Old Jul 15, 2004 | 07:34 PM
ABK's Avatar
ABK
Default Re: smoke from spark plugs (delScho)
cracked head or cracked sleeve if everything stated above was done.
the king.
Oct 19, 2006 12:09 PM
Scantron
13
Feb 3, 2006 09:18 AM
gray_civic_coupe
Jan 16, 2006 03:15 AM
bey
Jul 14, 2004 07:05 AM
