Will white NSX wheels fit my cw ITR?
Old Nov 23, 2001 | 01:01 PM
CrewChiefDoug's Avatar
Default Will white NSX wheels fit my cw ITR?
Is that not a good question? Thanks.
Old Nov 23, 2001 | 01:04 PM
Andrew Sites's Avatar
Default Re: Will white NSX wheels fit my cw ITR? (DougTypeR)
The factory front 16x7 NSX wheels (96-up) should fit. They have a 50mm offset -- same as the 16x7 Mugen MF10s. Realtime originally ran them back in 97.
Old Nov 23, 2001 | 01:10 PM
citanest's Avatar
New User
The front will fit for sure. dont' know how much they weight though
Old Nov 23, 2001 | 01:11 PM
BABY NSX's Avatar
Default Re: Will white NSX wheels fit my cw ITR? (Andrew)
Yup! The 97+ fronts do fit the ITR
Old Nov 23, 2001 | 01:39 PM
Dirty GS-R's Avatar
New User
Default Re: Will white NSX wheels fit my cw ITR? (BABY NSX)
How much do they weigh?
Old Nov 23, 2001 | 03:30 PM
nsxtcjr's Avatar
New User
Default Re: Will white NSX wheels fit my cw ITR? (2K1 GS-R)
They won't fit exactly, no.
Wrong. The NSX front wheel (all years) has a 55 mm offset, and the rear wheel (all years) has a 60 mm offset. The ITR has a 50 mm offset. So you may run into problems due to the difference in offset. You could get some spacers... but you might also need to replace the lugs.
The NSX front wheel also has a center bore that is different from the ITR's. The NSX front wheel has a 70 mm center bore, whereas the ITR has a 64 mm center bore. You will need to find a set of hubcentric rings that are fabricated to fit those wheels exactly, or you could run into problems due to the lack of hub centricity. (The NSX rear wheel has the same 64 mm center bore as the ITR.)
You can read about the NSX wheels here. Scroll down to the section "What About Hub Rings / Adapters / Spacers?" to see more about the need for hubcentric rings.
[Modified by nsxtcjr, 6:59 PM 11/23/2001]
Old Nov 23, 2001 | 04:43 PM
redteg1's Avatar
Default Re: Will white NSX wheels fit my cw ITR? (nsxtcjr)
40mm offset stock?
Old Nov 24, 2001 | 05:22 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Wrong.
then how come Realtime used them? i personally would do the same if the nsx fronts were not a grand a piece.
Old Nov 24, 2001 | 06:41 AM
nsxtcjr's Avatar
New User
Default Re: Will white NSX wheels fit my cw ITR? (rodney)
Because Realtime (a) gets NSX wheels for free, (b) doesn't mind using spacers and/or lugs and/or modding body panels to get particular wheels to fit, (c) probably swapped out the hubs for NSX hubs, etc etc etc.
It's not that you can't MAKE the NSX wheels fit; you can. But it will probably involve a lot of work and expense, and there are plenty of other wheels on the market that are designed to fit as is.
Old Nov 24, 2001 | 05:24 PM
Rodney's Avatar
what better reason to have them? i am in the process of a putting a ARC induction box from a ek (dual filter) in my car. why? different.....
Old Nov 24, 2001 | 08:59 PM
BABY NSX's Avatar
Your figures are correct. But I have been running 1998 NSX fronts on my car for 2 years now and I can tell you they do fit. Yes, I use centring rings to account for the different bore, but this is not unlike most aftermarket wheels so I don’t see a problem with it. You will also need to use sticky weights when balancing, as the clip-on weights will interfere with the lower trailing arm. A 5mm spacer would make things perfect, but my EXPERIENCE is that it is completely un-necessary!
They DO fit! No spacers required with 215x45 series tires.
Regards,
Old Nov 25, 2001 | 07:24 AM
nsxtcjr's Avatar
New User
As I said, ...
BABY NSX, where did you have your centering rings machined? They're not an off-the-shelf item. Places that sell aftermarket wheels will supply them with the wheels, but that doesn't apply to stock NSX wheels. I went to the Tire Rack and discussed this with their experts, and if I wanted to use my NSX wheels, I would have had to find a shop to machine them for me.
[Modified by nsxtcjr, 10:26 AM 11/25/2001]
Old Nov 26, 2001 | 11:35 AM
BABY NSX's Avatar
Actually they are an "off the shelf" item. A local wheel shop ordered them in for me. I paid 5 bucks for all 4. Not a huge expense if you ask me!
Regards,
Old Nov 26, 2001 | 12:52 PM
BABY NSX's Avatar
Default Re: Will white NSX wheels fit my cw ITR? (JOYRIDE II)
got some pics of the infamous nsx rims on your itr.i would like to sees
I have many pictures... But I need to find a place to host them. I'm going to try something tonight!
Regards
Old Nov 26, 2001 | 02:02 PM
TorontoR's Avatar
Hey BabyNSX, the only pic I could find of your car was from the ITR meet a few months ago. There was another ITR there with NSX wheels, who was it?
Old Nov 26, 2001 | 03:00 PM
nsxtcjr's Avatar
New User
Default Re: Will white NSX wheels fit my cw ITR? (TorontoR)
Yeah, you can spot the one with the NSX wheels because they have seven spokes.
So where are all the yellow and black ones?
Old Nov 26, 2001 | 03:18 PM
Dirty GS-R's Avatar
New User
Yellows are rare and black ones don't exist.
Old Nov 26, 2001 | 03:32 PM
TorontoR's Avatar
Well, the black one at the meet that time came up from Buffalo, the only black one I've ever seen, there was another yellow one that day, but the dude left early, as did a couple of other ITRs. Here are the rest of the pics which were posted here by other members a little while back:
Old Nov 26, 2001 | 03:36 PM
BABY NSX's Avatar
All I can say is:
salogni63
Honda Fit
Dec 19, 2012 11:53 AM
J_Marc
May 18, 2007 06:54 PM
2.2XDreams
Jun 11, 2004 11:22 PM
rudeS2k
Honda S2000
10
Oct 31, 2002 11:07 AM
IGGY
Apr 5, 2002 11:50 AM
