a little help with codes.... ( code 3 )
Old Jul 15, 2004 | 04:02 PM
sivik2nr's Avatar
Default a little help with codes.... ( code 3 )
I have a 99 civic hatch with a 94 ( jdm ) b18c engine and using the Skunk 2 conversion harness. I had an attempted theft a while ago, and my SAFC was stolen
I haven't driven the car in the few weeks and now that I start it up, I have a solid CEL. So i pulled the code and it's Code 3. Is that the MAF sensor?
How can I check the sensor it self? Would It have anything to do with my not having the SAFC anymore? The second part of the harness is wired to the ecu... but the part that connects to the unit itself was unplugged and taken. Nothing was cut or pulled.
Old Jul 15, 2004 | 09:39 PM
sivik2nr's Avatar
bumo
Old Jul 16, 2004 | 08:23 AM
H2B just chillin's Avatar
Default Re: (sivik2nr)
IF I COULD REMEMBER CORRECTLY ITS A MAP SENSOR (ICOULD BE WRONG)
Old Jul 16, 2004 | 09:25 AM
EE_Chris's Avatar
Default Re: a little help with codes.... (sivik2nr)
It really sounds like your MAP sensor isn't even connected to the ECU.
Old Jul 16, 2004 | 09:43 AM
Sack Master's Avatar
Default Re: a little help with codes.... (EE_Chris)
When your afc was stolen did you get all the wiring back the way it should be? That may be the biggest cause of your problems.
Old Jul 17, 2004 | 07:28 AM
sivik2nr's Avatar
yeah, well they just cut the harness off at the plug before the second part of the harness that wires to the ecu. I'm going to recheck all the connections and see. It doesn't look like it was yanked though :\
blood843
May 27, 2017 08:50 PM
Navy_Kyle
Aug 18, 2012 02:02 PM
SpoonEk253
Nov 8, 2006 08:12 PM
1337 Si
Oct 1, 2005 10:47 AM
