B16 Help...
I just installed a second gen b16 in my 92 civic dx started it up fri night ran real good, let it sit one night then tried starting it sun didn't start..so i thought it was dist cause everything else was working fine so i pulled a spark plug wit the wire connected to it and tried starting it, well when i pull the last cylinder the motor started up, weird so it wasn't the dist, mabye a tune up or fuel system so i put in my wires and plugs in the b16 from my gsr it started fine wit the p06 so i tried the jdm p30 didn't started at all then i put back the p06 now it won't start at all...maybe fuel pump or injectors?? thanks
Sorry about that, kinda stressed out want this motor to run, so now when i turn the car on in the acc postion, i don't hear the fuel pump turning on or hear any fuel running through the motor.
Sorry i gotta bring this back to life, Well i bought a new walbro fuel pump and started it running the p06, it took maybe 7 times then started up. Little white smoke out the muffler, then i turned it off and put in the p30 started up and ran like **** then died so i put back in the p06 and fuel pump won't turn on...mabye the ecu i am running or fuel pump relay? I am stuck please help me..thanks
I let the car sit for 10 mins now the fuel pump is turing on when in acc postion but car will not start still some sort of relay maybe??
Modified by XzzYzzX at 3:50 PM 7/30/2004
kc_kc
16
Dec 3, 2010 06:02 AM
RussHondaCRXVtec
Dec 16, 2003 09:37 PM
