post swap charging issue for b18c1
Old Jul 15, 2004 | 03:41 PM
ekfighter's Avatar
Default post swap charging issue for b18c1
hello all...
I have some sort of weird chaging issue. My headlights and interior lights run dim until about 4000 rpm in which they then will illuminate to full power. I have replaced alternator and the battery is charging fine. I think it might be wiring, ECU, or connection problems? Also, my defrost button turns on the front vent fan and my front vent fan button turns on defrost fan if this is part of issue. Im not sure. Lights will dim agian at lower rpms. Things worked fine pre swap. I have a 96 ek civic hatch. Any ideas? Thank you graciously.
Old Jul 15, 2004 | 04:12 PM
EKRacer's Avatar
Default Re: post swap charging issue for b18c1 (ekfighter)
I had that same headlight problem after my swap. There is a pin you can take out on your ECU, don't exactly remember which one buts it's the ALT-C one if you can get the pinouts. Unpin that and you're good.
Old Jul 17, 2004 | 09:05 PM
ekfighter's Avatar
Default Re: post swap charging issue for b18c1 (EKRacer)
Sweet!!!! Thanks ,bro.... appreciate it.
Dyln.bxtr
Aug 26, 2013 03:43 PM
fourdoorek
Oct 25, 2010 12:37 PM
994door
Jun 22, 2007 01:37 PM
CivicHB93JDM
May 4, 2005 10:50 AM
B16Vtec
Aug 23, 2001 09:34 AM
