Starter Solenoid Wire Mixup
There's two 14 mm nuts on the solenoid. Which one goes to the battery.
Thanks fs, I was kinda waiting for a confirmation from one other person before I hooked it up. I didn't wanna f it up and have to replace it this close the finishing my engine swap. That the one I also thought went to the battey. I didn't label it cause at the time the other wire was still connected to the starter, and for some reason I removed it after it was outta the engine.
So can anyone confirm please that the shorter terminal closer to the battery goes to batttery.
and which terminal of the battery goes to the fuse box under the hood? It got pulled out and I just wanted to be sure before I burn shtuff up.
thanks.
tk
thanks.
tk
That's just the solenoid. One of the bigger ones goes to the actual starter.....I'd take a pic of my starter to show you but it's mounted and those posts are on the bottom (oem motor...)
