Skunk 2 Intake Manifold on a GSR
Old Nov 23, 2001 | 09:13 AM
GSR -97's Avatar
New User
Default Skunk 2 Intake Manifold on a GSR
I'm considering upgrading to a S2 IM for my GSR.
Just wondering experiences from anyone here who's done it (gains to expect).
Also, do you have to upgrade the ECU ? Or can it run on the regular gsr one ?
Thanks
Old Nov 23, 2001 | 09:40 AM
Hapa DC5's Avatar
Default Re: Skunk 2 Intake Manifold on a GSR (GSR -97)
yeah your stock ecu is fine to run on it, when i swapped in mine it has a nice lil whistle a more flow you might notice it, remember it eliminates the secondary runners so if you thought your vtec was at 5570 nope it's at 4800.
Old Nov 23, 2001 | 09:42 AM
Mr. Softee's Avatar
Default Re: Skunk 2 Intake Manifold on a GSR (NemesisGSR)
i thought vtec was 4400
Old Nov 23, 2001 | 10:02 AM
GSR -97's Avatar
New User
So if the secondaries are removed,
do you get that awsome sound as if they're open all the time.
whhhaaaaaaaa!
I've heard 6-8 whp gain,
how much did you get yours for?
how much to install?
Old Nov 23, 2001 | 11:44 AM
FCdrifter's Avatar
New User
if you are completely stock and you switch out your IM your midrange is going to experience a good loss but I imagine it should make up for it uptop....?
Old Nov 23, 2001 | 01:20 PM
AK94GSR's Avatar
Default Re: Skunk 2 Intake Manifold on a GSR (96greengsr)
I haven't installed mine yet because I am waiting to put in cams, manifold, and reproggaming my ecu for a single runner set up. I heard you don't gain hardly any power when you don't have anything else on your engine.
Old Nov 23, 2001 | 01:35 PM
GSR -97's Avatar
New User
Default Re: Skunk 2 Intake Manifold on a GSR (AK94GSR)
I have type R cams in my gsr right now, adjustable cam gears which I'm not putting in till I can dyno it, and a CAI which I would have to change with the new IM.
Wouldn't I be able to adjust for that lost midrange power with my cam gears?
A few people have told me to go with the S2 IM.
would you think with my setup it would be worth it?
How much are the manifolds/install?
Thanks
Old Nov 23, 2001 | 01:36 PM
GSR -97's Avatar
New User
So my ECU will be looking for a second runner, and will that itself decrease power gains?
Old Nov 23, 2001 | 01:46 PM
ithrowpoop's Avatar
I installed a skunk 2 im on my gsr. All I have is i/h/e and suspension mods. I feel a big difference when v-tec kicks in at around 4500. Its a little louder but i feels good.
Old Nov 23, 2001 | 01:48 PM
Dirty GS-R's Avatar
New User
From what I understand the secondary runner works off a vacuum and not the ecu. Is this correct? If it is then your stock ecu will work fine.
Old Nov 23, 2001 | 03:53 PM
Comtechgsr2000s's Avatar
New User
Default Re: Skunk 2 Intake Manifold on a GSR (2K1 GS-R)
yes thats correct.
Old Nov 23, 2001 | 05:53 PM
FAST94GSR's Avatar
New User
Default Re: Skunk 2 Intake Manifold on a GSR (Mugenblkgsr2000)
use a sohc vtec ecu from a 92-95 civic. the secondaries work by vacuum yes but the computer will add fuel still. you'll be running too rich. try using a skunk ecu and lean it out with a vafc.
Old Nov 23, 2001 | 09:01 PM
Tweakmeister's Avatar
Default Re: Skunk 2 Intake Manifold on a GSR (FAST94GSR)
As per the dyno runs I saw, the Sk2 in a stock setup will give about 6-8 up top with a small sacrifice in the midrange. With some good tuning you can totally alter this however, and get good gains throughout (cams).
polishedturd
Dec 4, 2007 08:14 PM
team 15
Jun 18, 2007 12:22 AM
SkIp_Civic_Ek6
Apr 13, 2007 02:11 AM
DShowers
Nov 30, 2004 06:05 PM
jdhealy
Jun 6, 2003 03:34 PM
