5th gear grind
Old Jul 14, 2004 | 11:46 PM
RiCE On IcE 2's Avatar
Default 5th gear grind
whats it mean? seems 2 only happen shifting at high rpm full throttle.
Old Jul 14, 2004 | 11:47 PM
B2FiNiTY's Avatar
Default Re: 5th gear grind (RiCE On IcE 2)
Most likely syncro.
Old Jul 14, 2004 | 11:51 PM
is3oo's Avatar
try changing tranny fluid
Default Re: 5th gear grind (B2FiNiTY)
is that part of extend warranty or is it wear and tear? how much to get replaced prolly?
Old Jul 14, 2004 | 11:52 PM
B2FiNiTY's Avatar
Usually it is not covered but if your dealership is kind enough to pay for your own problem.
Old Jul 15, 2004 | 06:14 AM
Finland's Avatar
synchro, shift fork, and maybe even the gear, depending on how long you let it go on like this.
Definitely change the fluid and use Honda MTF, that will help quiet it down a bit, but eventually the synchro will need to be replaced. When you change the fluid, drain it through a coffee filter, and look for brass colored chips...that's your synchro..
Old Jul 15, 2004 | 09:46 AM
Default Re: (boost psycho)
what would cause it yo be shot? too much 3 to 5th lazy shifting?
Old Jul 15, 2004 | 09:53 AM
B2FiNiTY's Avatar
Default Re: (RiCE On IcE 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">what would cause it yo be shot? too much 3 to 5th lazy shifting?</TD></TR></TABLE>
That would be a cause. Also fast and hard shifting.
Old Jul 15, 2004 | 09:58 AM
Default Re: (B2FiNiTY)
how much does it normally run to get the synchro replaced.. can they replace individual synchros in the tranny or do they ahve to get a new tranny?
Old Jul 15, 2004 | 10:03 AM
B2FiNiTY's Avatar
You can replace certain ones. Depending on on miles, I would also recommend replacing certain bearings.
Estimate around $200+ for parts and much more on labor.
The 5th gear syncro is actually quite easy compared to the rest of them.
Old Jul 15, 2004 | 10:25 AM
obd2gsr's Avatar
try gm synchromesh before honda mtf.
gm sychromesh has helped grinds in numerous honda applications. do a search on synchromesh and you'll see.
also, gm synchromesh is the same as pennzoil/ac delco synchromesh. they sell gm synchromesh @ gm/chevy/pontiac dealers, and pennzoil @ certain autozones.
give it a whirl before you do anything else...
Old Jul 15, 2004 | 10:27 AM
B2FiNiTY's Avatar
Default Re: (obd2gsr)
Don't even bother trying syncromesh.
Try syncromesh MODIFIED.
Old Jul 15, 2004 | 10:33 AM
beign as I am too lazy to swap the fluid on my own and dont; really have time I should be able to go to pep boys and jsut give it to acura to try right? Will the fluid solve the problem or just delay the problem?
Old Jul 15, 2004 | 10:36 AM
B2FiNiTY's Avatar
It is chance. if the problem is bad then it will do nothing. If it's minor, then it will cover up the problem although it will always be there.
I wouldn't trust my car to pep boys.
Old Jul 15, 2004 | 12:08 PM
oh no meant get teh fluid from pep boys and give it to acura to put in
Old Jul 15, 2004 | 12:17 PM
Ph0eNix's Avatar
Had the same problem last Jan. I changed the tranny fluid and would still grind. I took it to Acura dealer for service since I still had warranty. They ended up changing all my syncros...no grinding ever since.
Old Jul 15, 2004 | 12:23 PM
Ill's Avatar
Ill
I had to go to the GM dealer to get Sychromesh Friction Modified. Pricey, $8-12 / qt. You need 3 qts.
Old Jul 15, 2004 | 12:24 PM
Default Re: (Ph0eNix)
were u under original warranty or the extended I have the extended but not sure if acura will consider it ware and tear? What acura did you go to?
Old Jul 15, 2004 | 10:45 PM
Ph0eNix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">were u under original warranty or the extended I have the extended but not sure if acura will consider it ware and tear? What acura did you go to?</TD></TR></TABLE>
I was still under original waranty...I took it to Mike Harvery Acura to service the 5th gear grind and got all my syncros replace under warranty. Pretty good service there...even left my car inside their garage at night. .
Old Jul 16, 2004 | 10:35 AM
hopefully it's covered in the extended.... says transmission in the extended book.. last i check transmission should include synchros right?
Old Jul 16, 2004 | 10:40 AM
B2FiNiTY's Avatar
Yes, but it is up the dealer's discretion whether to work on your car or not.
Old Jul 26, 2004 | 04:32 PM
jimmyjames's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Don't even bother trying syncromesh.
Try syncromesh MODIFIED. </TD></TR></TABLE>
What he said.
sixfiveoh
Mar 10, 2007 12:27 AM
BrownGSR
Oct 13, 2003 02:01 PM
TrueDC2
Oct 3, 2003 12:13 PM
hmongdude
Jul 14, 2003 01:17 PM
chuteBOXE
Apr 13, 2003 02:34 PM
