Going to do y7/y8 mini me swap.
Old Jul 14, 2004 | 09:34 PM
goofyej6's Avatar
Default Going to do y7/y8 mini me swap.
What else do i need and should i replace? TIA
y8 complete head
head gasket
y8 timing belt?
spark plugs
oil
coolant
Old Jul 14, 2004 | 09:41 PM
drewbie*'s Avatar
Default Re: Going to do y7/y8 mini me swap. (goofyej6)
waterpump
https://honda-tech.com/zerothread?id=554053 for more info.
Old Jul 14, 2004 | 09:52 PM
Civiclx's Avatar
you also need a d16y8 manifold that matches the obd of the head (obd2a vs obd2b) also the intake and exhaust mani gaskets, get a two pin iacv and also a d16y8 throttle body. Make sure to do the two step iacv fix. Wire the knock sensor with oem shielded grounded wire, and also put a resistor for the fuel tank pressure sensor or else a code 91 will happen. Good luck.
Old Jul 15, 2004 | 02:27 AM
goofyej6's Avatar
is it real necessary to change out the waterpump? and where do i put the resistor for the fuel pump?
Old Jul 15, 2004 | 05:00 AM
menkio's Avatar
lol.. you can keep your waterpump.
PLEASE DON'T POST INFO UNLESS YOU ARE SURE IT IS RIGHT.
Old Jul 15, 2004 | 06:21 AM
drewbie*'s Avatar
Default Re: Going to do y7/y8 mini me swap. (DewMota)
then dont change your old *** water pump watch it fail and have an overheating system...
Please stick that caplock key in your ***. thanks.
I'm only trying to save you from more work down the line.
Modified by Drew95eg at 7:55 AM 7/15/2004
Old Jul 15, 2004 | 06:24 AM
Buzzbomb's Avatar
Default Re: Going to do y7/y8 mini me swap. (Drew95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew95eg &raquo;</TD></TR><TR><TD CLASS="quote">then dont change your old *** water pump watch it fail and have an overheating system...
Please dont be gay unless your name is dewmota....</TD></TR></TABLE>
WERD.
Replacing the water pump is for preventative maintanence reasons only. You're going to have the engine apart, so why not put in a new pump and while you're in there, a new tensioner pulley as well.
Old Jul 15, 2004 | 07:50 AM
dsadas89das78934's Avatar
refer to my sig
Old Jul 15, 2004 | 08:18 AM
Tokyo_X-treme_Racer's Avatar
New User
Im wondering, why do a mini-me when you can just get a whole y8 setup?
Old Jul 15, 2004 | 08:23 AM
drewbie*'s Avatar
Default Re: (Tokyo_X-treme_Racer)
higher compression, less cost, more power... pick one
Old Jul 15, 2004 | 11:27 AM
Civiclx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tokyo_X-treme_Racer &raquo;</TD></TR><TR><TD CLASS="quote">Im wondering, why do a mini-me when you can just get a whole y8 setup?</TD></TR></TABLE>
more pain more gain, actually i was a minime but i DE minimed and got a y8 tranny and trust me, a dx with an ex tranny is faster than a dx with an ex head
Old Jul 15, 2004 | 12:12 PM
drewbie*'s Avatar
Default Re: (Civiclx)
yea if you are looking to upgrade everything you would want a tranny too, if you where on a budget get the tranny first
Old Jul 15, 2004 | 12:18 PM
goofyej6's Avatar
yea that's what i was thinking too but i got a good deal on the head. getting the tranny within a month =D 15 seconds here i come i hope!
Old Jul 15, 2004 | 12:28 PM
OR... if you're a big baller like me... you can do it all.
tranny, flywheel, pistons, rods, head, cam, valve springs, ITB's, uberdata
god i'm a retard
EJ6_OB
12
Aug 10, 2012 10:27 AM
97Ek9Civic
Aug 4, 2011 02:21 AM
devonic
Nov 26, 2009 07:45 PM
SOHC_civic_si
May 4, 2008 08:50 PM
88hondahatch
Feb 3, 2004 07:26 PM
