Tachometer red wire connection
Old Jul 14, 2004 | 09:23 PM
jdl3000's Avatar
Default Tachometer red wire connection
I need help. where did you guys connect your red wire(supposed to be connected to ignition 12V on/off switch) for your tachometer.
diagram and pix will be appreciated
thanx
Old Jul 14, 2004 | 09:26 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Tachometer red wire connection (jdl3000)
i'm assuming it's a aftermarket tach. i hooked it up to the gauge fuse so only when the idiot lights come on does it work. What car is it for? i'll see of i can look up colors tomaro.
Old Jul 15, 2004 | 04:26 AM
crx_88_si's Avatar
Default Re: Tachometer red wire connection (JC18)
One of the two plugs (spade terminals) are 12v ign, the other is 12v lights.
Old Jul 15, 2004 | 07:06 AM
ironchef25's Avatar
Default Re: Tachometer red wire connection (crx_88_si)
yup crx_88_si is correct. just installed mine 2 nights ago with crx_88_si help. i believe the left one is ign power. and the right is light power.. so hook up your 12v in the left and your light to the right of that and your good to go..
Old Jul 15, 2004 | 05:35 PM
jdl3000's Avatar
thanks
Randy1121
Lighting
Dec 20, 2013 05:08 PM
Honda Nub
Sep 21, 2012 11:04 PM
nickoz
Feb 29, 2008 06:46 AM
Suck my DX
11
May 12, 2007 01:13 PM
sjteg
Apr 22, 2003 06:35 PM
